Author Topic: KX250 engine ID  (Read 2507 times)
Offline Dirtbike BrainwashedMike
KX250 engine ID
« on: July 20, 2010, 07:54:07 pm »
Can anyone tell me if the engine number for a KX250 C, 83 model begins KX25CE or KX250C. Or is it something different?
Any help will be much appreciated,
Mike
Offline Hardo
Re: KX250 engine ID
« Reply #1 on: March 15, 2011, 11:04:56 am »
This is an old post, but as noone has responded I thought I would:
The KX250 C1 engines started with KX250CE00xxxx , and the 84's (C2) started with serial numbers KX250CE01xxxx
The bottom line is that if the cases are CE00, then it definitely originally came from an 83 model.
Hope that helps! ... if not, then I guess you may have died waiting....   :-[
Re: KX250 engine ID
« Reply #2 on: March 15, 2011, 08:27:10 pm »
Thanks Hardo
I was looking at a gearcase on ebay. Couldn't work out what model it was, so I let it go. Number was hard to make out even in the close up photo, it may have been restamped.  With the hassels I've had buying 2nd hand on the net, I don't get involved anymore without being 100% sure. I'll hang on to your info. for future reference. thanks again Mike
