Author Topic: Twin shocks and forks  (Read 1461 times)
Offline head
« on: July 20, 2010, 04:56:09 pm »
Building up a DR400 with RM swingarm. I am in need of a set of shocks 380mm eye to eye and possibly 140mm stroke. Any thing + or - 10mm would be OK. Even if they need rebuilding.  Also after a 38mm drum brake front end with at least 280mm travel. Possibly YZ250G forks or anything similar. Any help appreciated.
Re: Twin shocks and forks
« Reply #1 on: July 20, 2010, 05:19:58 pm »
Rear shocks, use DR 500 1983 as they are of right spring rate and travel.... cheap as chips to buy  ;)
Dr 400 don't need a lot of front braking, as it's all done with engine braking.
If your going to use a YZ front end, check the offset and trail difference's. You don't want to upset the handling or it will not corner too well.
Offline head
« Reply #2 on: July 21, 2010, 11:53:53 pm »
Does any body out there have 1983 DR500,  or similar shocks they wish to sell?
