Author Topic: Case paint ?  (Read 2311 times)
Offline Mike52
  • 81 KTM 125 LC
Case paint ?
« on: July 18, 2010, 07:54:22 pm »
Hi guys what paint do you use on your c/cases when you want that smick factory look ? :)
monaro308
Re: Case paint ?
« Reply #1 on: July 18, 2010, 09:13:53 pm »
I used a can of satin black brake caliper paint on my RM cases and being heat resistant @ under $20.00 a can i thought it was ok.
Offline rocketfrog
Re: Case paint ?
« Reply #2 on: July 19, 2010, 09:39:21 am »
It's called VHT Case paint, most good auto parts stores sell it and it is about as good as you will get. For best results you should allow to dry and low bake at 100 C as per the instructions on the can. One can will do an engine and have some to spare, I use the same stuff on hubs. This stuff is designed to withstand oil and fuel as well as high temp. Around $20.00 a can.
