Author Topic: Triple tree stem extension  (Read 3069 times)
Offline jimson
  • Sanctuary point N.S.W
« on: July 15, 2010, 08:48:06 pm »
G'day viewers I need my stem to be longer  :-[ so I thought about making a shaft to slide down inside the stem to reinforce it to the length I need and then cut the stem in the middle and pull it apart to the size I need and then weld the stem to the shaft  :o well is this as clear as mud  :-\  jimson
Re: Triple tree stem extension
« Reply #1 on: July 15, 2010, 09:04:03 pm »
why not get a new shaft machined it's got to be way stronger and every thing stays in alignment too
Offline brent j
« Reply #2 on: July 15, 2010, 09:22:34 pm »
What's the shaft for Jimson?
When I did my XT500's I found the shaft from Yamaha YZ/IT triples was was too short and Suzuki too long. I used Suzuki shafts and shortened them. I ran the bearing surface further down, chased the thread a bit longer cut the weld holding the nut in place, shortened the end of the shaft and rewelded the nut.
Easier than it sounds!
Brent
PS Yamaha and Suzuki shafts interchange on YZ, IT, PE & RM. Honda are different
Offline jimson
« Reply #3 on: July 15, 2010, 09:38:21 pm »
Its Honda and if I told you what I was trying to build you would think I was a nutter  ;D I'm trying to do this with out spending money well anymore money  ::) jimson
« Reply #4 on: July 15, 2010, 09:41:25 pm »
Have you tried any of the drugs they advertise in e-mails ::) ;D
Offline brent j
« Reply #5 on: July 15, 2010, 09:46:41 pm »
Any chance a shaft from another model may fit?
Offline jimson
« Reply #6 on: July 15, 2010, 09:55:42 pm »
Yes but our local wrecker has closed down  :'( and I think I would get caught if I started pulling triple trees off bikes in the street that aren't mine  ;D jimson
Geoff you should delete those emails not read em  :D unless you need em.
« Reply #7 on: July 15, 2010, 10:11:47 pm »
Me too. So I've been told. :-[
I once extended a steering stem by welding in a sleeved extension when I fitted CZ forks and triple clamps to a Bultaco M11 Metisse. At the time I was a DLI certificated pressure vessel welder and also had a number of other welding qualifications yet I never felt at totally ease knowing that the stem was welded so I ended up machining a new one to suit from a longer Yamaha stem of some sort. My advise is to make a new one or search the wreckers for one that suits. Welding is a no no no matter how good a job you think you did.
« Last Edit: July 15, 2010, 10:15:12 pm by firko »
