Author Topic: Removing rust from inside steel tank  (Read 8393 times)
Offline FDR
« on: July 14, 2010, 10:18:05 pm »
Old steel mx tank has patches of rust inside.
Any advice on how to remove.
Regards, FDR
lc4
Re: Removing rust from inside steel tank
« Reply #1 on: July 15, 2010, 06:26:57 pm »
Rust remover from Super Cheap Auto , pour in put cap on a give it a good shake. Keep a eye on the rust being removed and when happy flush out with a water hose. Dry out with heat gun or hair dryer and throw a bit of two stroke oil in a give it a good shake.
« Reply #2 on: July 15, 2010, 08:10:37 pm »
If you have one an old cam chain when shakeing inside the tank
Offline FDR
« Reply #3 on: July 15, 2010, 08:43:58 pm »
Thanks Slakewell, will give it a try.
Offline retrowrex
« Reply #4 on: July 15, 2010, 08:48:55 pm »
Have heard that some ball bearings or something like that is the go as well.  Don't know for sure.  All my bikes have plastic tanks.  With no rust inside them.
Retro
Apparently you can only ride one bike at a time, and hence you should only have one bike.  :(
Offline FDR
« Reply #5 on: July 15, 2010, 09:01:12 pm »
Cheap option, pebbles from a mates driveway, will mix with rust remover and shake.
« Reply #6 on: July 15, 2010, 09:10:06 pm »
also If you have a cement mixer and a few blankets and block it firmly in the mixer you could give it a few rolls to clean it out ,needs to be done a few times..Have seen this illustrated in a bike mag.Don't sue me if it crash and burns though.  ;D
bit more info in the below.
http://ozvmx.com/community/index.php?topic=144.0
Offline jimson
  • Sanctuary point N.S.W
« Reply #7 on: July 15, 2010, 09:45:41 pm »
phosphoric acid glooves googles once you do it it leaves a cover over the metal and slows the rust return don't get it on your paint work. jimson
« Reply #8 on: October 06, 2010, 08:04:36 pm »
Try this.    works for me ;)                    Molasses  first - and then rinse with Phospheric acid.
http://virtualindian.org/projrust.htm
« Last Edit: October 06, 2010, 08:07:12 pm by oldfart »
Offline ji107
« Reply #9 on: October 06, 2010, 11:56:18 pm »
Try to get hold of a product called 'Corrodip'. I get it in SA from a yachting chandlery. About $35 for a litre, water based.Mix with 4 litres of water, pour into tank and leave o/nite. Where the liquid wes in contact with the steel, like new. Will have to turn it around a few times to get all surfaces.
Liquid can be kept indefinately in a plastic container
DT_Mania
« Reply #10 on: October 07, 2010, 01:22:38 am »
I know that there is also a product where they put a thin plastic film inside of the tank. They blow it in with pressure like a balloon. That gives you relieve from the rust messing with your carbie.
Offline shorelinemc
  • life sucks&then you die
« Reply #11 on: October 07, 2010, 09:39:09 am »
get a POR 15 kit removes rust,preps the surface and then coating works great and will fill small holes
211kawasaki
« Reply #12 on: October 07, 2010, 10:17:27 am »
Molasas
10% with water; check every day
will be good as new in a few days - and taste good to
get from local horse shop
pbear62
« Reply #13 on: October 08, 2010, 12:04:05 pm »
Be careful if you're going to put ball brgs, nuts & bolts inside - too much vigorous shaking can cause tiny dents from the inside! I've heard of people using white vinegar to dissolve the rust too. After treating the rust, some people line the tank with Kreen or POR sealer - main problem with these is that if ever you need to weld/heat the tank later, they give off toxic fumes & the sealer gets stuffed by the heat.
« Reply #14 on: October 08, 2010, 01:01:18 pm »
I use this hydrochloric acid and wouldnt waste my thime with anything else. It works fast and works well.
That is exactly the reason why liners fail, if you dont get all the rust out first before pouring in the liner. No point putting a liner in to cover up and hide the rust.
