Author Topic: YZ pistons in MX250 what year works without mods?  (Read 9722 times)
Offline cyclegod
  • Sunny PERTH W.A
    • cyclegod on "youtube"
« on: December 30, 2007, 02:40:44 pm »
What year YZ250 pistons work in 74 MX250s ?
« Last Edit: December 30, 2007, 02:57:40 pm by cyclegod »
Ban BLACK rims NOW
Re: YZ pistons in MX250 what year works without mods?
« Reply #1 on: December 30, 2007, 06:51:37 pm »
i didnt think they did unless they are later ones.  I got Dt and MX 250 ones here what size you looking for, hook you up with a few standards i could :O)
Offline vandy010
  • #789 MX125a BMCC Brisbane
« Reply #2 on: December 30, 2007, 07:12:35 pm »
whilst on the subject of these piston thingies,
and to add to the confusion of this thread perhaps,
does anyone know if the 75/76 dt250 pistons will work in the 74 model mx/dt?
yeah i know i've changed the direction a little but it's all about getting the bikes going right...
"flat bickie"
Offline cyclegod
  • Sunny PERTH W.A
« Reply #3 on: December 30, 2007, 07:25:48 pm »
DT250 engine didn't change much 74-76, neither did the pistons they just stopped using dyke rings on top. the YZ piston uses a cut away on the intake side instead of two round holes which allows better intake breathing (apparently). But at some point the gap between pin and crown increased, so I need to know which year that was so I don't have to modify the barrel by adding a spacer plate.
Ban BLACK rims NOW
« Reply #4 on: December 30, 2007, 07:44:11 pm »
the MXb does the same thing with the curve cut away and i think 76+ Dt also,
Can you use the MXb piston ? cyclegod ?
Vandy if its Dt it will fit, all that model used the same piston A-B-C  you could also upgrade it to the MXA - single ringer :O)
Dt Part # = 438-11635-01-00
Part Description = PISTON (1ST) ( just change the 5 to 6 to 7 etc to go up in over sizes)
Also these models are said to be the same Piston =
DT2 1973 250
DT250A 1974 250
DT250B 1975 250
DT250C 1976 250
DT3 1973 250
TY250E 1978 250 Trials
« Reply #5 on: December 30, 2007, 07:52:04 pm »
Info not available in the Wiseco catalogue?
Offline cyclegod
  • Sunny PERTH W.A
« Reply #6 on: December 30, 2007, 07:53:52 pm »
Probably, but since I don't have one it's hard to say.
Ban BLACK rims NOW
Offline vandy010
« Reply #7 on: December 30, 2007, 08:07:10 pm »
freaky's answered my question.
my mx250a arrived as a non-runner with no piston so i'm in the dark from the get-go.
my bike will need a rebore so which piston for me?
thanks freaky.
i dig these kinds of convo's, very helpfull indeed...
"flat bickie"
« Reply #8 on: December 30, 2007, 08:46:42 pm »
Direct from serco catalolgue   page 51  if this is any help
YZ 250  1976-79              bore 70 mm         stroke 64 mm
IT  250  1978-80
DT 250  1974-79
MX 250  1973-1975
Offline DJRacing
  • YZ125X
« Reply #9 on: December 30, 2007, 09:09:50 pm »
Could it be that the YZ250C,D,E,F piston will work in the MX250A? If so Wiseco list that the DT1;DT2;DT3 and MX can run the same piston. The number is 234PS for standard all the way up to 234P8 = 2mm oversize
234P6 = 1.5mm
234P4 =1mm
234P2 = .5mm
« Reply #10 on: December 30, 2007, 11:09:59 pm »
thanks freaky.
what size is it on now ? piston crown should be stamped .25, .50, .75 so youll know what its on now, if ya like i can lend you a piston to get it running so at least you know where your at, then when you know its a runner you can get a new piston, which you will need to take with you anyway to the reborers so they can get the right clearances with the piston you intend to use
Offline vandy010
« Reply #11 on: December 31, 2007, 09:43:53 am »
thanks freaky but as i said it came with no piston. the rebuild is still a bit down the track as theres other things i'm wanting to do first.
it's been a while since i measured the bore but it will most likely need either 1.25 over or 1.5 over as i'm pretty sure it's 1mm over now.
"flat bickie"
Offline jimson
  • Sanctuary point N.S.W
« Reply #12 on: December 31, 2007, 05:09:57 pm »
DJ the early DT1 250 didn't have reeds so the back of the piston has no cut away so the piston is different to the reed models I think they are DT2 maybe.I have heard you can use a IT 250 piston in a DT2 reed model but have not seen this done with my own eyes. jimson
« Reply #13 on: January 01, 2008, 08:01:44 pm »
if the bore is over 71mm you will need to be After market,  start you wiseco hunt !
