Author Topic: 72 alpina,or sherpa rear wheel offset  (Read 3328 times)
Offline matcho mick
    • Moto Tumbi
« on: July 06, 2010, 06:57:39 pm »
can anyone tell me rear wheel offset,run ruler from brake drum to rim edge for me,(or to centre if tyres off)tia!,cheers mick
« Last Edit: July 06, 2010, 11:27:59 pm by matcho mick »
Offline matcho mick
    • Moto Tumbi
Re: 72 alpina,or sherpa rear wheel offset
« Reply #1 on: July 08, 2010, 11:28:00 am »
ended up doing 70mm to centre,(now you's can all tell me it's wrong ::)),
Offline huskibul
« Reply #2 on: July 08, 2010, 11:59:29 am »
   Mick, my crusty/trusty 72' sherpa run's at 68-70mm from brake backing plate/swingarm surface to rim edge (outside bead) if that make's any sense, :D cheers
« Last Edit: July 08, 2010, 12:03:10 pm by Huskibul »
Offline matcho mick
    • Moto Tumbi
« Reply #3 on: July 08, 2010, 12:11:43 pm »
shite,now you tell me ::),i only had bare wheel to do!,Huskibul ,whats measurement from brake drum edge to rim edge?,
Offline huskibul
« Reply #4 on: July 08, 2010, 01:07:26 pm »
 Mick when you say "brake drum edge"do you mean drum-hub/sprocket surface?
Offline matcho mick
    • Moto Tumbi
« Reply #5 on: July 08, 2010, 02:35:06 pm »
yes mate,the wheel i'm doing is bare hub,no sprocket,or backing plate etc,go from your sprocket's inside edge to rim?,ta mick
Offline huskibul
« Reply #6 on: July 08, 2010, 02:39:25 pm »
       43mm hope it helps
Offline matcho mick
    • Moto Tumbi
« Reply #7 on: July 08, 2010, 02:51:33 pm »
beauty Huskibul,i got 42,(43 on the bumps ;D),thanks for that,cheers mick
