Author Topic: Wanted: 1977 Yamaha YZ 125D Alloy Swingarm  (Read 7544 times)
Offline DCPlasticsguy
« on: July 06, 2010, 06:42:29 am »
Let me know if anybody has one that they are willing to part with along with a price. Thanks!
Offline oldyzman
  • 250 two stroke!
Re: Wanted: 1977 Yamaha YZ 125D Alloy Swingarm
« Reply #1 on: July 06, 2010, 10:13:35 pm »
Mate, Just curious.. are you after a non std part cause from memory i reckon the D hada tubular steel swingarm and the E had a Alloy one.
Cheers Brett
« Reply #2 on: July 07, 2010, 01:41:43 am »
Yes, it needs to be an aftermarket unit. I can't use the 1978 model swing arm because it is a pre 1978 class.
Offline the farm
« Reply #4 on: August 01, 2010, 03:51:59 pm »
 ??? has anyone fitted a 250/400 D s/arm into a 125D or is it way too much trouble. i cant see much on this subject in the yamaha section, but i reckon one of you guys must know. maybe too wide at the pivot point or something. how much have they sold for in the past, seems kinda expensive or im out of touch with prices, ...
Offline motomaniac
« Reply #5 on: August 01, 2010, 04:16:45 pm »
yer too much troulble , toowide is just at the pivot is just the start.
Offline E74
« Reply #6 on: August 01, 2010, 04:58:29 pm »
Matt Park Just did it with a 250/400D DG Swingarm I sold him, he said it was quite easy and the bike is up and running perfectly.
Offline the farm
« Reply #7 on: August 01, 2010, 05:15:46 pm »
be great if matt could tell us what he had to do, cut, weld , machine whatever....
Offline motomaniac
« Reply #9 on: August 01, 2010, 08:40:38 pm »
 The 125 is 20mm narrower at the pivot bit the same at the axle .so to do it right you need to bend the side arms somewhere.
« Reply #10 on: August 01, 2010, 10:06:00 pm »
I'm pretty sure that the 125 has a smaller dia. axle as well
Offline motomaniac
« Reply #11 on: August 01, 2010, 10:10:28 pm »
yes GMC its 1 or 2 mm smaller . the overall swingarm length is shorter as well.
Start making GMC ARMS ;)
« Reply #12 on: August 01, 2010, 10:17:00 pm »
Nah, got too many projects as it is.
#148
« Reply #14 on: August 19, 2010, 07:59:25 am »
whoops, just realised its sold  :-\ , sorry, good pictures for a replica one to be made though  ;)
