Author Topic: oils specs for YZ125x, yz250/400c forks  (Read 1883 times)
« on: July 04, 2010, 08:39:19 am »
is anyone else running these with conventional springs rather than the air canisters?
Or is someone able to make an educated guess on the oil level/weight you'd run in this scenario?
the standard spec was 394 ml of 20wt for the 125x, I can't find anything for the 250/400 c's, the online service data sheets are all for the D models.
Re: oils specs for YZ125x, yz250/400c forks
« Reply #1 on: July 04, 2010, 09:41:32 am »
with after market springs i have bought in the past they say depress forks without springs in them fill oil to 6 in from top of the fork tube.use oil of your choice
jim
all i have is the 125x book and air forks
« Reply #2 on: July 04, 2010, 09:44:50 am »
thanks jim, that'll give me a good starting point
paul
