Author Topic: Help Guys. Husky problemo  (Read 3915 times)
Offline Mike52
  • 81 KTM 125 LC
« on: July 01, 2010, 07:27:47 pm »
Hi.
Gotta 1986 240 Wr and am trying to remove the primary drive gear.
Have just bought a hydraulic puller in frustration but am not game to use it
 because I don,t want to wreck the water pump drive thingy on the end of the crank. ::)
Suggestions?
Re: Help Guys. Husky problemo
« Reply #1 on: July 01, 2010, 08:35:03 pm »
Buy an air cooled bike?
use a small 3 jaw puller
Offline Mike52
  • 81 KTM 125 LC
« Reply #2 on: July 01, 2010, 08:54:25 pm »
[quote author=Lozza link=topic=13870.msg138576#msg138576 date=1277980503
Yer real handy Lozza. Tried the small 3 jaw puller and that,s why I bought the bigun.
The trick is ,
the gear is the same on both versions the water and the air :D
« Last Edit: July 01, 2010, 09:01:29 pm by Mike52 »
Offline Mike52
  • 81 KTM 125 LC
« Reply #3 on: July 02, 2010, 01:40:57 pm »
Job done , only busted one new puller. :'(
Could have been worse. :)
« Reply #4 on: July 02, 2010, 09:01:02 pm »
You could own 2 Husky's
Offline Mike52
  • 81 KTM 125 LC
« Reply #5 on: July 03, 2010, 07:14:49 pm »
You might have a point Lozza.
Still gotta get the crank outta other side case.
Seems to be just a touch tight.
They never wanted these things to come apart did they. :)
whitey
« Reply #6 on: July 03, 2010, 10:46:24 pm »
Raced an 85 model back in the day just check your water pump housing,Remember Brooke Flanagan won the A4DE in 86 on a 240wr great bike lucky you! :)
Offline sa63
« Reply #7 on: July 14, 2010, 08:04:24 am »
Not sure about the end of your crank, but my 510 te primary drive was pretty bloody tight.. Only room for a 2 jaw puller, tight as I dared then a wack with a hammer on the puller bolt . It came off so fast it hit the side of the shed..good luck!!!
Offline Mike52
  • 81 KTM 125 LC
« Reply #8 on: July 14, 2010, 09:07:30 pm »
Yep same gear , same result. :o
Going back together now so panic is over. [ For now] :)
Water pump interesting. Resleaved with stainless. Looks pretty now, hope it works. :)
