Author Topic: one down,2 to go?  (Read 2082 times)
Offline matcho mick
    • Moto Tumbi
one down,2 to go?
« on: June 24, 2010, 01:05:54 am »
bugger bugger,SDR's motors spread in 1 corner,original bigends rs (finally :(),super pioneers spread all over bench,renewing bearings/seals,the k/start shafts buggered,so now i have to splt & raid a plonker motors k/start shaft,still, only 1 more sleep till CRC,plenty of time ::), :P
Offline matcho mick
    • Moto Tumbi
Re: one down,2 to go?
« Reply #1 on: June 26, 2010, 02:12:21 am »
geezas what a mission,super pioneers got coarser splines on the gear,& kick start shafts,naturally the po kept both levers :(,sorted that out,swaps the ignition from the now dead SDR ,ahhggg the bloody flywheel shafts l/h thread,naturally when po kept igntion as spares,i didn't get a nut,all my other ossas are r/h thread,pharrkkk,1am,is not good,eureka,bless you Montesa,16mm l/h thread flywheel nut,(& it was finger tight),there is a god 8),,so moving to the c/shaft sprocket swap,hmmm nuts excessive,i'll use SDR's,no ,wrong size again ::),think i'll give trophy races later today a miss,just do club rounds sunday,(it's probly piss down sunday ::)),going ni nighs, :P
Offline micks
« Reply #2 on: June 26, 2010, 10:41:03 pm »
 when it`s all together all you need is it to fall off the stand and crack your tank!!
