Author Topic: WP4860 Fork Service For Dummies  (Read 12054 times)
Ji Gantor
« on: June 21, 2010, 07:01:25 pm »
This is a modern upsidedown fork.
Should be pretty similar to a Pre 90 fork.
Any way like all forks they started leaking oil last ride so today I purchased a pair of new fork seals and a litre of 5w oil.
I already have all the tools required to service these forks.
Tight nuts
Ji
Ji Gantor
Re: WP4860 Fork Service For Dummies
« Reply #1 on: June 21, 2010, 07:04:59 pm »
First turn your rebound and compression clickers clockwise to find out what your current setting is.
Then grip the fork and undo the cap with a pin spanner.
Tight nuts
Ji
Ji Gantor
« Reply #2 on: June 21, 2010, 07:08:45 pm »
Lower the outer tube down.
Tight nuts
Ji
Offline holeshot buddy
  • sunshine coast qld
« Reply #3 on: June 21, 2010, 07:56:42 pm »
they are nothing like the pre 90 fork ji ;)
follow me to first turn
Ji Gantor
« Reply #4 on: June 21, 2010, 08:30:19 pm »
Sorry Holeshot I don't have a pair of Pre 90's to see.
I just guessed that they should be similar.
Okay these are just modern forks.
Nothing like any VMX bike including Pre 90.
Tight nuts
Ji
Ji Gantor
« Reply #5 on: June 21, 2010, 08:53:21 pm »
Grasp the spring and pull down so a 22mm open spanner can be fitted to the hex.
The hex has a steel plate top and bottom so when the spring is released the spanner is kept in place.
Tight nuts
Ji
Ji Gantor
« Reply #6 on: June 21, 2010, 09:05:18 pm »
Place a 24mm socket or ring spanner on the cap nut and loosen.
Tight nut
Ji
Ji Gantor
« Reply #7 on: June 21, 2010, 09:11:45 pm »
Remove the cap.
Then remove the spring and let drip into a pan.
Now we can pour all the old oil into a measuring container.
Tight nuts
Ji
Ji Gantor
« Reply #8 on: June 21, 2010, 09:30:36 pm »
Hi Wasp,
Yes I use Stahlwille, Snap On, KC Pro and Repco spanners.
I like the Stahlwille because they are so light and thin.
Tight nuts
Ji
Ji Gantor
« Reply #9 on: June 21, 2010, 09:33:09 pm »
With the spring out, the outer tube pushed down and the oil drained it is time to place the fork into a vice.
Tight nuts
Ji
Ji Gantor
« Reply #10 on: June 21, 2010, 09:36:22 pm »
With the fork held securely in a vise pry the rubber plug off the bottom of the fork.
Place a 19mm socket onto the compression cap and loosen.
Tight nuts
Ji
Ji Gantor
« Reply #11 on: June 21, 2010, 09:44:35 pm »
Now that the cartridge is free both ends we can lift it out of the outer tube and place on a drip tray.
Tight nuts
Ji
Ji Gantor
« Reply #12 on: June 21, 2010, 09:49:45 pm »
Gently pry out the mud wiper.
Tight nuts
Ji
Ji Gantor
« Reply #13 on: June 21, 2010, 09:50:48 pm »
Lever out the circlip.
Tight nuts
Ji
Ji Gantor
« Reply #14 on: June 21, 2010, 09:55:03 pm »
With the circlip removed the inner and outer tubes are now free.
This said they do not just come apart, you have to use the two tubes like a slide hammer.
Two or three slides and the seal will pop out of its recess and the two tubes will come apart compleatly.
Remove all the parts and place on a drip tray in order so they will go back on the way they came off.
Tight nuts
Ji
