Author Topic: Will a TS185 crank will fit in a TM400?  (Read 2007 times)
cultofthumpers
« on: June 20, 2010, 06:35:56 am »
I can get a TS185 crsnk, flywheel and stator cheap but I don't want to buy unless I know it will fit. Has anyone here used a TS185 crank in a TM400??
DR
Re: Will a TS185 crank will fit in a TM400?
« Reply #1 on: June 20, 2010, 06:43:14 am »
No, Flywheel and stator may fit but not the crank. A TS400 or TM400 crank is the one you want.
cultofthumpers
« Reply #2 on: June 26, 2010, 12:02:10 pm »
Thanks Doc. found a TS400 crank, will pick up the other bits from a 185
