Marque Remarks
Honda
CR480 crank advice
Topic: CR480 crank advice (Read 2247 times)
suzuki 400
C-Grade
CR480 crank advice
June 17, 2010, 10:40:20 pm »
can i put a 480 83 crank in a 82 ,are they the same need a little help on what can be swapped over
caps 999
Re: CR480 crank advice
June 17, 2010, 11:05:17 pm »
i have a 82 crank and im in need of an 83 if you want to make a swap
MUGEN power
090
June 18, 2010, 05:21:46 pm »
I am 98% sure they are the same.
suzuki 400
C-Grade
June 19, 2010, 01:01:41 am »
im in the throws of buying one or the other but need a 100% yes on the 83 fitting in the 82 before commiting ,so i can,t help its to connect to darans head caps
caps 999
Reply #4 on:
June 19, 2010, 08:30:45 am »
It's not the head that's the problem it's the main drive gear I'm not sure weather 82 83 are the same
MUGEN power
Marque Remarks
Honda
CR480 crank advice
