Author Topic: Headstem seals  (Read 1665 times)
Headstem seals
« on: June 16, 2010, 08:49:59 pm »
Can someone help me with finding seals to fit taper roller races, I have a all balls set to fit my Ty250 & have discovered that the lower bearing is the same size as what is going into my CZ.
The bearing size is 48x30x13mm & the all balls kit has a seal that fits on the inner portion. The kit fits quite a number of different yamahas as a conversion but seals are not listed separately
Hopefully the bearing size is a common standard fitment & someone can tell me the model it fits or better still supply a part number for me to order
