Author Topic: CR250R 1984  (Read 1399 times)
CR250R 1984
« on: June 16, 2010, 01:16:57 pm »
Hello all,
I have a project 1984 CR250R which I'll never get to. It has the usual drama's, clutch cover/water pump is corroded and someone has done an awful job of trying to weld it, the frame is rusty underneath where they all seem to be (easy repair) and the shock shaft is bent. The pipe is ordinary as well. The tank & shrouds are very good to excellent, the LH side cover & rear mudguard need replacing, you could clean up & use the RH side cover & front guard. The radiators are good as are the forks, wheels, swing arm, seat, etc. The hardest part will be finding a clutch cover. It was running before I aquired it, however the engine was out when I got it so I have not had it running. Pm or email [email protected] for photo's. Try here before it goes on ebay. $1000.
