Author Topic: RM400 tank on a PE400 frame  (Read 1994 times)
rohan
« on: June 16, 2010, 08:56:35 am »
Can anyone tell me will an RM400 tank bolt up exactly onto a PE400 frame or will some modification be required?
Re: RM400 tank on a PE400 frame
« Reply #1 on: June 16, 2010, 12:46:52 pm »
Yes but you will also require the RM seat.
Offline southnztim
« Reply #2 on: June 16, 2010, 03:17:23 pm »
I've just fitted an Rm tank to my Pe. I had to make up a new set of mounts for the front of the tank. Neither the Pe or Rm's original ones lined up. Also you need to change the seat to an Rm. I added rubber to the Pe rubber and re-covered it. Came together well.
