Author Topic: KDX175 carb/jetting.  (Read 8600 times)
« on: June 13, 2010, 06:49:22 pm »
I'm piecing together a KDX175, but don't have the right carby.
I do have a 34mm round slide Mikuni from an IT175F, which I assume will be close to right.
1. What size/type is the original KDX carb?
2. What jets lived in it?
Offline Tex
Re: KDX175 carb/jetting.
« Reply #1 on: June 13, 2010, 09:06:54 pm »
What about the "project bike clearance sale"?!  ;D
« Reply #2 on: June 13, 2010, 09:19:07 pm »
With a couple of exceptions, nobody has shown much interest.
Will wait until everyone's CD7 hang-overs have cleared and put up individual ads with pics.
« Reply #3 on: June 13, 2010, 10:17:25 pm »
from my zedder
Bike = KDX175-A1
Year = 80
Size = 175
Desciption = KDX175
Part Count = 565
BR9EV SPARK PLUG,BR9EV 13
B9ES SPARK PLUG,B9ES 28
K92070-043 SPARK PLUG,B9ES,B9ES 1
11001-1023 CYLINDER HEAD,FLAT BLACK,11001-1052 1
11004-1022 CYLINDER HEAD GASKET,11004-1052 3
11004-1052 CYLINDER HEAD GASKET 3
11005-1060 CYLINDER,ELECTRO-FUSE 2
11009-1018 REED VALVE GASKET,11060-1562 20
11009-1040 ENGINE COVER GASKET,RH,11060-1463 7
11009-1076 FLOAT VALVE GASKET 27
11009-1079 FLOAT CHAMBER GASKET 6
11009-1080 FLOAT CHAMBER PLATE 6
11009-1175 CYLINDER BASE GASKET,11060-1439 5
11009-1177 ENGINE COVER GASKET,LH,11060-1566 5
11009-1190 CABLE GUIDE GASKET,11009-1191 13
11009-1191 CABLE GUIDE GASKET 17
11009-4001 FUEL TANK CAP GASKET 8
11011-1047 AIR CLEANER BODY 4
11012-1099 SWING ARM CAP 14
11012-1109 AIR CLEANER CAP 8
11012-1111 AIR CLEANER CAP 8
11012-1116 BRAKE PEDAL FITTING CAP 5
11012-1117 SUSPENSION ARM CAP 15
11012-1123 AIR CLEANER CAP 8
11013-1031 AIR CLEANER ELEMENT 4
11034-1688 HEADLAMP FITTING BRACKET 4
11034-1693 HEADLAMP FITTING BRACKET 4
11060-1439 CYLINDER BASE GASKET 5
11060-1463 CLUTCH CRANKCASE COVER GASKET 7
11060-1562 REED VALVE GASKET 20
11060-1566 GENERATOR COVER GASKET 5
12021-1007 REED VALVE ASSEMBLY 24
12053-1039 CHAIN GUIDE,REAR 12
12053-1043 CHAIN GUIDE,FRONT 3
13001-1031 PISTON,STD,13001-1048 1
13001-1048 ENGINE PISTON 3
13002-1004 PISTON PIN 27
13008-5025 PISTON,RING SET,STD,13008-5034 1
13008-5034 PISTON RING SET 3
13031-1032 CRANKSHAFT ASSEMBLY 3
13031-5010 CRANKSHAFT,COMPLETE 5
13033-1004 NEEDLE BEARING,KBK1620198 2
13034-1002 NEEDLE BEARING,BIG END 5
13034-1022 NEEDLE BEARING,KT222816 1
13035-1001 CRANK PIN 12
13037-1062 CRANKSHAFT,LH 3
13037-1063 CRANKSHAFT,RH 3
13044-5017 CONNECTING ROD ASSEMBLY 3
13061-1013 KICKSTARTER BOSS,13061-5001 16
13061-5001 KICK PEDAL BOSS 15
13064-1008 KICK PEDAL ASSEMBLY,13064-5005 9
13064-5005 KICK PEDAL LEVER ASSEMBLY 8
13066-1005 KICKSTARTER SHAFT 6
13070-008 KICK SPRING GUIDE 24
13070-1010 CABLE GUIDE 6
13078-009 RATCHET,13078-1052 49
13078-1052 RATCHET,KL250-D2 105
13081-1040 CLUTCH ASSEMBLY 3
13086-1001 CLUTCH WHEEL 13
13087-1014 CLUTCH HUB 3
13088-039 CLUTCH FRICTION PLATE,13088-1015 51
13088-1015 FRICTION PLATE 53
13089-003 CLUTCH PLATE,STEEL 56
13091-015 CLUTCH HOLDER 9
13091-1071 CLUTCH PUSHER HOLDER 11
13095-1027 CLUTCH HOUSING 3
13097-1033 GEAR,PRIMARY,23T 3
13114-1004 PUSHER CLUTCH 8
13127-1026 DRIVESHAFT 3
13128-1026 SHAFT,OUTPUT 3
13129-1181 GEAR,DRIVESHAFT,2ND 3
13129-1182 GEAR,DRIVESHAFT,3RD & 4TH 3
13129-1183 GEAR,DRIVESHAFT,5TH 3
13129-1184 TOP GEAR DRIVESHAFT 3
13129-1185 LOW GEAR,OUTPUT SHAFT 3
13129-1186 GEAR,OUTPUT SHAFT,2ND 3
13129-1187 GEAR,OUTPUT SHAFT,3RD 3
13129-1188 GEAR,OUTPUT SHAFT,4TH,13129-1324 2
13129-1189 GEAR,OUTPUT SHAFT,5TH 3
13129-1190 TOP GEAR,OUTPUT SHAFT 3
13129-1324 TRANSMISSION SPUR GEAR 3
13140-1034 SHIFT FORK 5
13140-1035 SHIFT FORK 5
13140-1037 SHIFT FORK 3
13142-017 SHIFT DRUM PIN PLATE 23
13144-1031 ENGINE SPROCKET,12T,13144-1049 2
13144-1032 ENGINE SPROCKET,13T,13144-1050 2
13144-1036 ENGINE SPROCKET,11T 18
13144-1049 SPROCKET,OUTPUT,12T 18
13144-1050 SPROCKET,OUTPUT,13T 18
13156-1033 GEAR CHANGE PEDAL ASSEMBLY,13156-1088 2
13156-1050 CHANGE PEDAL LEVER 3
13156-1088 CHANGE LEVER 4
13161-1005 GEAR CHANGE LEVER ASSEMBLY,13161-1031 7
13161-1031 CHANGE LEVER,COMPLETE 7
13168-1059 GEAR CHANGE LEVER,A 5
13168-1066 STARTER LEVER 3
13169-1225 GEAR CHANGE DRUM PLATE 5
13206-1001 KICKSTARTER GUIDE,13206-1059,13206-1061 37
13206-1059 KICK GUIDE,13206-1061 40
13206-1061 KICK GUIDE 62
13236-1022 CLUTCH RELEASE LEVER ASSEMBLY 5
13236-1023 GEAR CHANGE LEVER,B 5
13239-1031 GEAR CHANGE DRUM ASSEMBLY 3
13244-1003 CHANGE DRUM STOPPER ASSEMBLY 5
14001-5047 CRANKCASE SET 3
14014-1003 POSITIONING PLATE 7
14025-4002 HEADLAMP COVER 11
14026-1012-21 FRONT CHAIN COVER,FLAT BLACK 15
14031-1048 ENGINE COVER,LH,FLAT BLACK 4
14032-1033 ENGINE COVER,RH,FLAT BLACK,14032-1034 5
14032-1034 ENGINE COVER,RH,FLAT BLACK 1
14069-003 BREATHER 64
14073-1037 AIR CLEANER DUCT,14073-1066 4
14073-1066 DUCT 5
16001-1250 CARBURETOR ASSEMBLY 1
16002-1006 CABLE ADJUSTER 39
16003-004 CABLE ADJUSTER LOCK NUT 182
16004-1003 MIXING CHAMBER TOP 6
16006-016 THROTTLE VALVE SPRING 22
16007-1007 THROTTLE VALVE SEAT 16
16008-010 CIRCLIP 292
16008-011 CABLE GUIDE CIRCLIP 40
16009-1063 JET,NEEDLE,6DH7 1
16012-016 PLUNGER CAP 11
16013-008 STARTER PLUNGER SPRING 58
16013-009 STARTER LEVER SPRING 8
16014-006 SCREW 68
16016-1014 STARTER PLUNGER ASSEMBLY 3
16017-1060 JET,NEEDLE,#Q-4 2
16021-1028 THROTTLE ADJUSTING SCREW 1
16022-007 THROTTLE STOP SCREW SPRING 191
16025-1047 THROTTLE VALVE,CA2.0 1
16030-022 FLOAT VALVE ASSEMBLY 5
16031-025 FLOAT ASSEMBLY 6
16032-008 FLOAT PIN 331
16038-009 CRANKCASE COVER GASKET 56
16039-015 STARTER PLUNGER CAP 68
16049-006 MAIN JET COVER 39
16065-1007 CARBURETOR HOLDER 6
16065-1017 NEEDLE JET HOLDER 9
16073-014 COLLAR 49
16076-003 CIRCLIP 54
16115-018 OIL FILLER 239
18001-1106 MUFFLER ASSEMBLY 2
18002-1081 MUFFLER BODY 1
18071-003 CONNECTOR SPRING 84
21003-1029 STATOR ASSEMBLY,MAGNETO 3
21007-1027 MAGNETO FLYWHEEL 3
21119-1015 IGNITER 2
21121-1032 IGNITION COIL,21121-1254 6
21121-1254 IGNITION COIL 9
21130-022 SPARK PLUG CAP,21130-1006 23
21130-1006 SPARK PLUG CAP 120
21160-1009 SPARK PLUG CAP ASSEMBLY 10
21169-001 PLUG CAP TERMINAL 116
23001-4001 HEADLAMP ASSEMBLY 9
23004-4001 HEADLAMP 11
23005-4001-7F HEADLAMP BODY,LIME GREEN,23005-5002-7F 11
23005-5002-7F HEADLAMP BODY,COMPLETE,LIME GREEN 11
23008-4001 HEADLAMP SOCKET 10
23020-018 NUT,4MM 430
23020-023 HEADLAMP RIM FITTING NUT 123
23021-004 WASHER 170
23021-012 WASHER,PLAIN,5MM 159
23025-075 TAIL LAMP 11
23026-040 TAIL LAMP LENS 32
23027-044 TAIL LAMP CASE 31
23028-020 TAIL LAMP GASKET 32
23036-4001 TAIL LAMP BRACKET 6
23069-4001 TAIL LAMP BODY 6
25001-1099 METER ASSEMBLY 6
25009-004 WASHER,5.2X16X16X1.2T 208
26011-1067 WIRE LEAD 4
26011-1068 WIRE LEAD 5
26011-1069 WIRE LEAD 5
27004-4001 HEADLAMP SWITCH 15
27010-1018 ENGINE STOP SWITCH ASSEMBLY 50
32002-1115 FRAME 1
32029-1122 ENGINE BRACKET,FRONT,32029-1140 4
32029-1123 ENGINE BRACKET,REAR 5
32029-1140 ENGINE BRACKET 5
32052-1009 FUEL TANK BRACKET 14
32052-1036 FUEL TANK FITTING BRACKET 4
32085-1016 KICKSTARTER STOPPER 50
32099-1011 CONTROL HOUSING,RH. 11
32099-1012 CASE DUST SHIELD 5
32099-1014 CASE GRIP,UPPER,RH 22
33001-1051 SWING ARM,33001-1069 1
33001-1069 SWING ARM,COMPLETE 3
33032-1015 SWING ARM PIVOT SHAFT,33032-1020 6
33032-1020 SWING ARM SHAFT 11
33040-043 CHAIN ADJUSTER 103
34003-1053 FOOTREST STEP HOLDER,RH,34003-1088 2
34003-1054 FOOTREST STEP HOLDER,LH 5
34003-1088 STEP HOLDER,RH 5
34006-004 FOOTREST SPRING,LH,92081-1254 26
34006-005 FOOTREST SPRING,RH,92081-1255 26
34024-1041 SIDE STAND 8
34025-008 SIDE STAND SPRING 86
34028-1004 FOOTREST STEP,RH,34028-1033 12
34028-1005 FOOTREST STEP,LH,34028-1034 12
34028-1033 STEP 17
34028-1034 STEP 17
35004-1042-6W FRONT FENDER,LIME GREEN,35004-1076-6W,35004-1233-6W 7
35004-1042-7F FRONT FENDER,LIME GREEN,35004-1076-6W,35004-1233-6W 8
35004-1076-6W FRONT FENDER,LIME GREEN,35004-1176-6W,35004-1233-6W 23
35004-1176-6W FRONT FENDER,LIME GREEN,35004-1226-6W,35004-1233-6W 35
35019-1017 REAR FENDER FLAP 5
35019-1034 REAR FENDER FLAP 5
35022-1050-6W REAR FENDER,LIME GREEN 1
35022-1068-6W REAR FENDER,LIME GREEN 6
36001-1087-6W SIDE COVER,LH,LIME GREEN 6
36001-1088-6W SIDE COVER,RH,LIME GREEN,36001-1105-6W 1
36001-1105-6W SIDE COVER,LIME GREEN 6
39007-1003 SUSPENSION ARM 3
41002-1087 TIRE,300-21 M17 F 7
41002-1088 TIRE,400-18 M20 R 4
41022-031 TUBE,350/375/410-18 127
41022-1023 TUBE,300-21,41022-036 12
41022-1024 TUBE,400/460-18,41022-031 6
41023-1009 RIM BAND 41
41023-1010 RIM BAND 23
41024-010 BEAD PROTECTOR,1.60A 164
41024-011 BEAD PROTECTOR,1.85B 67
41025-1017 RIM,FRONT,1.60-21 4
41025-1018 RIM,REAR,1.85-18 4
41029-1019 SPOKE,FRONT,INNER,LH 7
41029-1020 SPOKE,FRONT,INNER,RH 7
41029-1021 SPOKE,REAR,INNER,RH. 7
41029-1022 SPOKE,REAR,INNER,LH 7
41030-1016 SPOKE,FRONT,OUTER,LH 7
41030-1017 SPOKE,REAR,OUTER,RH 7
41030-1018 SPOKE,REAR,OUTER,LH 7
41032-1001 SPOKE NIPPLE,41032-1074 7
41032-1074 SPOKE NIPPLE 7
41034-1016 FRONT BRAKE DRUM ASSEMBLY 5
41034-1017 REAR BRAKE DRUM ASSEMBLY 7
41035-1030 FRONT BRAKE PANEL ASSEMBLY 3
41035-1031 REAR BRAKE PANEL ASSEMBLY 3
41042-013 DUST COVER 18
41048-015 BRAKE SHOE,41048-1091 40
41048-1076 BRAKE SHOE 73
41048-1091 BRAKE SHOE 40
41049-002 BRAKE SHOE SPRING,92081-1766 168
41049-011 BRAKE SHOE SPRING,92081-1550 57
41050-1016 FRONT BRAKE CAMSHAFT 4
41050-1017 REAR BRAKE CAMSHAFT 4
41053-1018 FRONT BRAKE CAM LEVER 7
41053-1019 FRONT BRAKE CAM LEVER 5
41059-024 SPEEDOMETER GEAR 19
41060-015 SPEEDOMETER PINION 43
41062-005 SPEEDOMETER CABLE BUSHING 152
41063-001 THRUST SPEED PINION WASHER 677
41064-011 SPEEDOMETER GEAR RECEIVER 19
41065-004 THRUST WASHER 27
41068-1042 AXLE,FRONT 3
41068-1043 AXLE,REAR 3
41068-1045 AXLE,REAR 1
41078-009 SPEED GEARCASE ASSEMBLY 15
41082-001 SPRING PIN 600
42019-010 BRAKE SHOE,41048-1076 59
42036-1009 REAR BRAKE SLEEVE 18
42036-1031 SWING ARM SLEEVE 12
42036-1035 REAR PANEL SLEEVE,RH 14
42041-1038 REAR SPROCKET,47T 6
42041-1043 REAR SPROCKET,50T 4
42041-1044 REAR SPROCKET,52T 6
43001-1043 BRAKE PEDAL 5
43007-1018 REAR BRAKE TORQUE LINK 5
43011-1019 BRAKE ROD 9
43012-001 BRAKE ROD SPRING 337
44001-1120 FRONT FORK 1
44005-1030 FORK OUTER TUBE,LH 5
44006-1030 FORK OUTER TUBE,RH 5
44013-1041 FORK INNER TUBE 1
44022-1030 FORK CYLINDER 5
44026-1043 FORK SPRING,INNER 1
44026-1056 FORK SPRING,INNER 1
44028-1004 FORK SPRING,GUIDE 72
44029-1015 FORK CAP,TOP 4
44037-1021 STEERING STEM 6
44039-1018 STEERING STEM HEAD 6
44041-040 BOLT,FORK CYLINDER 254
44041-065 BOLT,FORK TOP 45
44043-052 WASHER 32
44045-002 FORK DRAIN PLUG GASKET 426
44045-057 FORK CYLINDER GASKET 280
45014-1052 SHOCK ABSORBER,REAR 1
46003-1054 HANDLEBAR 4
46012-1003 HANDLEBAR HOLDER 11
46019-1010 THROTTLE GRIP ASSEMBLY,46019-1012 4
46019-1012 GRIP ASSEMBLY 10
46041-017 CASE,UPPER,RH,32099-1014 16
46055-009 CABLE ADJUSTING SCREW 298
46056-006 CABLE ADJUSTER LOCK NUT 245
46058-018 FRONT BRAKE LEVER 34
46060-010-21 FRONT BRAKE LEVER HOLDER,FLAT BLACK 19
46071-003 DUST COVER 27
46075-1012 GRIP,RUBBER,LH,46075-1015 6
46075-1015 GRIP 13
46076-1003 FRONT BRAKE LEVER ASSEMBLY 19
46076-1004 CLUTCH LEVER ASSEMBLY 19
46092-021 CLUTCH LEVER 34
46094-014-21 CLUTCH LEVER HOLDER,FLAT BLACK 19
46098-015 STEERING STEM CAP 53
46102-1016 SUSPENSION ARM ROD,46102-5001 2
46102-5001 UNI-TRAK ROD ASSEMBLY 2
49006-1009 FORK BOOT,49006-1009-BD 28
49006-1009-BD FORK BOOT,BLACK 28
49006-1035 BALL JOINT BOOT 9
49006-1045 BALL JOINT BOOT 10
49006-1046 BALL JOINT BOOT 10
49047-1009 SHIFT ROD,10X90 67
49099-1025 MUFFLER PIPE BAFFLE 2
51001-1033-6W FUEL TANK,LIME GREEN,51001-5107-6W 2
51001-5107-6W FUEL TANK,LIME GREEN 3
51023-1009 FUEL TAP ASSEMBLY,51023-1115 32
51023-1115 FUEL TAP ASSEMBLY 117
51049-1060 FUEL TANK CAP 8
51049-4001 FUEL TANK CAP,51049-1060 3
51049-4002 FUEL TANK CAP,51049-1060 7
520QRX118 DRIVE CHAIN,520QRX118,TSB 3
53001-1074 SEAT ASSEMBLY,53001-1111 1
53001-1111 SEAT ASSEMBLY 3
54001-1020 SPEEDOMETER CABLE 5
54005-1020 FRONT BRAKE CABLE 5
54011-1034 CLUTCH CABLE,54011-1068 5
54011-1068 CLUTCH CABLE 4
54012-1059 THROTTLE CABLE 3
55020-1038 CHAIN GUARD 7
55020-1040 ENGINE GUARD 3
56008-008 TOOL BAG 157
56018-1140 SIDE COVER EMBLEM 3
56018-1157 MARK 12
56027-1855 FUEL TANK EMBLEM,LH 3
56027-1856 FUEL TANK EMBLEM,RH 3
59051-1008 KICKSTARTER GEAR 7
59051-1009 IDLE GEAR KICKSTARTER 13
59266-1001 SUSPENSION BALL JOINT 12
59266-1002 SUSPENSION BALL JOINT 12
59266-1003 TORQUE LINK BALL JOINT 9
70175-1029 ENGINE ASSEMBLY,KDX175A1 1
92001-1003 BOLT,RETURN SPRING,92001-1401,92001-1455 158
92001-1040 BOLT,HEX HEAD,8X32 17
92001-1042 BOLT,HEX HEAD,8X28 110
92001-1077 BOLT,HEX HEAD,8X67,92001-1410 6
92001-1078 BOLT,HEX HEAD,8X96,92001-1393 4
92001-1079 BOLT,HEX HEAD,8X106,92001-1394 4
92001-1179 BOLT,CHAIN ADJUSTER 35
92001-1182 BOLT,10X45 9
92001-1228 BOLT,HEX HEAD,8X35,92001-1381 80
92001-1230 BOLT,HEX HEAD,8X40 100
92001-1232 BOLT,HEX HEAD,8X56,92001-1398 30
92001-1237 BOLT,HEX HEAD,8X70,92001-1390 39
92001-1295 BOLT,HEX HEAD,14X54 4
92001-1296 BOLT,HEX HEAD,14X59,92001-1335 3
92001-1306 BOLT,HEX HEAD,12X40 3
92001-1317 BOLT,HEX HEAD,14X50 12
92001-1335 BOLT,HEX HEAD,14X60 12
92001-1381 BOLT,8X35,92001-1577 91
92001-1383 BOLT,8X40,92002-1838 146
92001-1386 BOLT,8X55 30
92001-1390 BOLT,8X70,92001-1583 47
92001-1393 BOLT,8X95,92002-1416 7
92001-1394 BOLT,8X105 7
92001-1398 BOLT,FLANGED,8X55 42
92001-140 BOLT,HEX HEAD,6MM 47
92001-1401 BOLT,RETURN SPRING,92001-1455 368
92001-1410 BOLT,8X69 10
92001-1439 BOLT,8X50 9
92001-1455 BOLT,EXCLUSIVE MASS P 713
92001-1577 BOLT,FLANGED,8X35 101
92001-1578 BOLT,92002-1838 151
92001-1583 BOLT,FLANGED,8X70 87
92002-1416 BOLT,FLANGED,8X90 10
92002-1813 BOLT,SIDE STAND 380
92002-1838 BOLT,FLANGED,8X4O 159
92003-078 BOLT,5X18 42
92003-157 BOLT,SIDE STAND FITTING,92002-1813 136
92004-1026 CYLINDER STUD 21
92009-1037 SCREW,4X5 17
92009-1159 SCREW,2X6,92009-1172 14
92009-1172 SCREW,2X6,BLACK 244
92009-1287 SCREW,6X14 313
92009-4002 ADJUSTING SCREW,4X43 11
92009-4003 HEADLAMP SCREW 20
92011-023 SCREW,PAN HEAD 71
92011-037 SCREW,PAN HEAD 31
92015-006 NUT,12MM 150
92015-1014 NUT,8MM 257
92015-1015 NUT,16MM 43
92015-1078 NUT,6MM 682
92015-1124 NUT,LOCK,8MM 241
92015-1193 NUT,FLANGED 687
92015-1546 NUT 281
92015-1596 NUT,LOCK,46056-005 160
92015-1962 NUT,92210-1184 509
92015-4004 NUT,WING,6MM 113
92016-036 NUT,16MM 11
92016-062 AIR CLEANER CAP NUT 47
92019-007 NUT,LOCK,8MM,92015-1124 96
92019-008 NUT 392
92019-009 NUT,LOCK,12MM 113
92019-011 NUT,LOCK,14MM 83
92019-021 NUT,LOCK,10MM,92015-1962 455
92020-017 NUT,CAP,322N0500 90
92022-077 OIL PUMP BANJO WASHER 562
92022-1019 WASHER,PLAIN 129
92022-1045 WASHER,PLAIN 35
92022-1053 WASHER,PLAIN 14
92022-1063 LOCK WASHER 8
92022-1094 LOCK WASHER,92022-1277 14
92022-125 WASHER,6.5X20X1.6T 752
92022-1277 WASHER,16.8X32X1.6 24
92022-198 WASHER,PLAIN 185
92022-2014 SPRING WASHER,461F0500,461F0500A 604
92022-218 WASHER,8.5X23.5X4.5 22
92022-223 THRUST WASHER 14
92022-268 WASHER,PLAIN 26
92022-269 WASHER,PLAIN 204
92022-276 WASHER,PLAIN,8MM 60
92022-315 WASHER,PLAIN 176
92022-4001 TAIL LAMP WASHER 6
92022-4005 HEADLAMP WASHER 19
92024-039 LOCK WASHER 120
92025-1116 SWING ARM SHIM 21
92026-011 WASHER,SIDE 64
92026-1072 FORK SPRING,SPACER 1
92027-1040 COLLAR 51
92027-1045 COLLAR 238
92027-1073 FRONT BEARING COLLAR 9
92027-1081 COLLAR 72
92027-1206 REAR AXLE COLLAR 7
92027-1207 REAR BRAKE COLLAR 15
92027-1228 FUEL TANK FITTING COLLAR 12
92027-1244 ENGINE SPROCKET COLLAR 5
92027-1260 COLLAR 43
92027-1440 COLLAR,13X18.3X21.5 113
92027-272 COLLAR,13X18.3X21.5,92027-1440 11
92027-4002 TAIL LAMP COLLAR 6
92028-1081 CLUTCH BUSHING 3
92028-1087 SUSPENSION ARM BUSHING 12
92033-025 CIRCLIP,25MM 574
92033-1005 OUTER FORK SNAP RING 8
92036-004 PISTON PIN CIRCLIP 45
92036-018 CIRCLIP 251
92037-016 CABLE CLAMP 48
92037-056 CARBURETOR CONNECTING HOSE CLAMP 55
92037-061 INLET PIPE CLAMP 83
92037-1064 CABLE CLAMP 79
92037-1072 CABLE CLAMP 13
92037-1073 CLAMP 13
92037-1169 MUFFLER CLAMP 5
92037-1173 SPARK PLUG CAP CLAMP 371
92037-1186 AIR CLEANER DUCT CLAMP 12
92037-171 CLAMP,92170-1526 57
92037-4001 HEADLAMP CLAMP 11
92037-513 CLAMP,92037-1173,92037-3024 189
92038-001 WOODRUFF KEY 664
92038-003 PRIMARY PINION WOODRUFF KEY 152
92043-064 BRAKE ROD FITTING PIN 173
92043-102 PIN 24
92043-1024 BRAKE PIN 36
92043-1037 DOWEL PIN,10X8.2X14 636
92043-1060 CHANGE DRUM PIN 11
92043-1069 FOOTREST STEP FITTING PIN 25
92043-125 PIN 126
92045-1002 BALL BEARING,6003VC3,601B6003U 32
92045-1009 BALL BEARING 38
92045-1010 BALL BEARING,92045-1211,92045-1304 31
92045-1304 BALL BEARING 91
92046-043 NEEDLE BEARING 24
92046-1007 NEEDLE BEARING 5
92046-1009 NEEDLE BEARING 50
92046-1031 NEEDLE BEARING,HMK2030 28
92047-017 STEERING STEM BEARING 312
92049-002 OIL SEAL,SB16244 135
92049-1009 FORK OIL SEAL,OUTER,92049-1216 62
92049-1068 OIL SEAL,TBJ25407 115
92049-1216 FORK OUTER TUBE OIL SEAL 93
92049-1250 OIL SEAL,92049-1482 127
92049-1482 OIL SEAL 130
92050-013 OIL SEAL,SC25376 132
92051-005 OIL SEAL,TB13225.5 771
92055-022 O-RING 277
92055-1051 FORK TOP O-RING 71
92055-1077 MUFFLER O-RING,50.8MM 4
92057-1051 CHAIN,520X118TR 5
92058-1002 CHAIN JOINT,520 14
92059-061 BREATHER PIPE 65
92059-1017 BREATHER TUBE,3.5X6.5X290 12
92059-1025 OVERFLOW HOSE 10
92059-1084 HOSE,6.5X11.5X240 5
92059-4001 TUBE,5X7X500 10
92063-103 JET,MAIN,#132.5R 15
92063-104 JET,MAIN,#135R 16
92063-105 JET,MAIN,#137.5R,92063-1087 13
92063-1087 JET,MAIN,#A137.5 17
92063-116 JET,MAIN,#140A 13
92063-117 JET,MAIN,#142.5R 10
92064-024 JET,PILOT,#40 38
92065-058 CHECK VALVE GASKET 964
92067-001 OIL DRAIN PLUG 275
92069-028 BULB,6V,17/5.3W 37
92069-4001 BULB,6V,35/25W 11
92070-3002 SPARK PLUG,BR9EV 9
92072-030 BAND,SHORT 624
92072-031 BAND,MIDDLE 662
92072-042 FUEL TANK BAND 65
92072-056 WIRING HARNESS BAND 560
92072-076 FUEL TANK BAND 30
92072-077 HEADLAMP BAND 18
92072-1008 BOOT BAND 52
92072-1011 BOOT BAND,LH 9
92072-1040 CABLE CLAMP 13
92075-1018 CYLINDER DAMPER,RUBBER 5
92075-1046 DAMPER,RUBBER 14
92075-1060 MUFFLER FITTING DAMPER 20
92075-1176 DAMPER,RUBBER 20
92075-118 DAMPER,RUBBER 19
92075-1209 METER DAMPER,RUBBER 35
92075-1220 FUEL TANK FITTING DAMPER 16
92075-1221 FUEL TANK DAMPER 9
92075-1226 SEAT DAMPER 12
92075-1229 CYLINDER DAMPER 16
92075-1236 HEADLAMP FITTING DAMPER 4
92075-1249 REAR SHOCK DAMPER 10
92075-4009 HEADLAMP DAMPER 22
92075-4010 HEADLAMP DAMPER 22
92077-1013 METER TRIP RESET KNOB 15
92081-020 KICK PEDAL SPRING 362
92081-076 CHANGE LEVER SPRING 262
92081-1059 RETURN SPRING 26
92081-1061 GEAR CHANGE LEVER SPRING 7
92081-1129 TENSION SPRING 207
92081-119 SPRING 22
92081-1200 THROTTLE STOP SCREW SPRING 21
92081-122 RATCHET SPRING 249
92081-123 CLUTCH SPRING 26
92081-1235 REAR SHOCK SPRING 1
92081-1236 REAR SHOCK SPRING 1
92081-1254 FOOTREST SPRING,LH 35
92081-1255 FOOTREST SPRING,RH 35
92081-1348 REAR SHOCK SPRING,STD 1
92081-1550 BRAKE SHOE SPRING 112
92081-1766 BRAKE SHOE SPRING 245
92081-4003 FOCUS ADJUSTING SPRING 11
92082-005 KICK STARTER SPRING 34
92090-024 STEERING STEM NUT,92015-1546,92015-1596 72
92091-029 BOLT,6X14,92009-1287 40
92093-1004 OIL SEAL 32
92093-1036 FORK DUST SHIELD,OUTER 5
92093-4001 HEADLAMP SEAL 11
92104-002 LIQUID GASKET 987
92108-011 SPOKE TIGHTENER 73
92110-019 SPARK PLUG WRENCH 27
92122-1002 CHAIN ROLLER ASSEMBLY,92122-1013 4
92122-1003 ROLLER,92122-1014 16
92122-1013 ROLLER ASSEMBLY 9
92122-1014 ROLLER 21
92150-1508 BOLT 265
92150-1509 BOLT,112G0616 350
92170-1526 CLAMP,65MM 77
92210-1184 NUT 499
« Reply #4 on: July 02, 2010, 10:27:44 am »
« Reply #5 on: July 02, 2010, 10:30:05 am »
Even though the carbies are different the jet-needle from my 88 KDX200 fitted the 175 carb.
HTH
« Reply #6 on: July 02, 2010, 08:18:57 pm »
Thanks Geoffers. Interesting that an IT175F also runs a VM34SS - but with a 360 main jet!
Something else I meant to ask you: Did I get the stator cover with the motor?
If so, what have I done with it!?
whitey
« Reply #7 on: July 03, 2010, 10:37:35 pm »
They were a 34 mm mikuni just digging up jetting specs remember mid range was pretty fluffy.
« Reply #8 on: July 06, 2010, 10:28:36 am »
Maybe not. I've been looking around for it but the wreckers removed the flywheel for me so I may not have recieved it.
Offline YUMASTEPSIDE
« Reply #9 on: July 07, 2010, 09:38:29 am »
Geoff, you coming to Rockley ??
             Roger
« Reply #10 on: July 07, 2010, 07:48:03 pm »
             Roger
Afraid not, I was really hoping to but just can't get my life organised enough to get away.
I was looking forward to the ride and the chance to meet some of you guys.
Hopefully you will be running some more in the future.
Their are plans for 6 Vinduros in Vic, next year.
