Clubroom
Tech Talk
tt500 yz125x fuel tap repair kit
Topic: tt500 yz125x fuel tap repair kit (Read 1814 times)
jimg1au
June 09, 2010, 12:26:58 pm »
hi
can repair kits be bought for these types of fuel taps.methenol has helped perish the rubber inside
jim
Rossvickicampbell
Re: tt500 yz125x fuel tap repair kit
June 09, 2010, 01:48:14 pm »
Jim - if it is the one I am thinking of with the 4 holed rubber insert - the insert is not available as a spare part - however many Yamahas between about 73 and 80 had the same fuel taps so maybe just buying another tap might help? By the way - they all tend to pass/leak like a sieve
Rossco
Nathan S
Superstar
HEAVEN #818
June 09, 2010, 04:33:41 pm »
This is the type that screws on to the male threaded fitting on the tank, with the steel plate held on my two small phillips head screws. On/Off only.
Jim, a new tap is $50. I want one too - go you halvies on postage?
pancho
June 09, 2010, 04:49:01 pm »
Seems doomed to failure if you're running methanol. I use a ball valve on my XT slider no leaks and adequate flow. cheers wally.
Clubroom
Tech Talk
