Author Topic: CD 7 Maintenance  (Read 2272 times)
Ji Gantor
CD 7 Maintenance
« on: June 06, 2010, 08:14:04 am »
This is just a reminder to all servicing their bikes for CD 7 especially those with multiple bikes.
It is easy to get distracted while changing the oil.
So double check that you definitely
Put oil in the gear box,
Took the rag out of the air box before you installed the air filter,
Torqued up the axles and swingarm pivot bolts,
Pumped up the tyres,
Tightened the chain,
Torqued up the triple clamps,
Turn the fuel tap to off,
Torqued up the cylinder and head bolts,
Topped up the fork oil,
Adjusted the brakes,
Foot peg return springs work,
Handle bar ends are plugged,
Throttle returns to idle by spring,
Steering head bearings are tight,
Intake manifold is tight without air leaks,
Locktited all nuts and bolts and
installed the springs on that new muffler
If not done this stuff could ruin your whole time at CD so take the time and go over it again.
Good luck and tight nuts
Ji
Re: CD 7 Maintenance
« Reply #1 on: June 06, 2010, 08:49:37 am »
Ticked all the above box's.    Just need to need to do a bit of work on the body. ;D      family recons I have screw loose. :D
Ji Gantor
« Reply #2 on: June 06, 2010, 09:34:57 am »
Addendum 1
Water or coolant in the radiator,
Bike stand,
Tighten spokes,
Tight wheel bearings,
Carb jets,
In line fuel filter,
Fixed grips,
Lubricated cables,
Tightened gear shift lever bolt,
Tightened kickstarter bolt and
Seal under fuel tank cap.
Ji
Offline pancho
« Reply #3 on: June 06, 2010, 12:02:09 pm »
Hey Ji, there's a few points you've made where I would suggest 'adjust' rather than tighten. Also what I find is a must is to have a list of items not to leave home without, like I often seem to do. Over the years i've managed to leave behind things like boots, helmet! plug spanner, money, caution, route map the list goes on as i'm sure others will attest to cheers wally.
Ji Gantor
« Reply #4 on: June 06, 2010, 12:49:18 pm »
Hi Wally,
Very true mate.
I started another thread about what to put into your kit bag to help prevent forgotten items.
When pumping up or checking tyre pressure make sure to check the rim locks are nice and tight.
I could start another list of what not to do.
At the top of the list would be Don't Armor all your seat.
If you have trouble staying in the saddle now wait till you armor all the seat.
Ji
