Author Topic: MX6 shock length ?  (Read 4519 times)
Offline Husky500evo
MX6 shock length ?
« on: June 04, 2010, 07:06:10 am »
Would any Can Am gurus know the correct eye to eye shock length for an '80 MX6 250 with the steel swingarm ? Also would you know the amount of shaft travel on the standard shocks ?
Offline Canam370
Re: MX6 shock length ?
« Reply #1 on: June 04, 2010, 08:27:00 am »
Length  415mm
stroke   155mm (total shaft length to top eye fitting)
Bumper length  45mm
 Hope these help 8)
« Last Edit: June 04, 2010, 08:31:38 am by Canam370 »
« Reply #2 on: June 04, 2010, 08:39:15 am »
I would have to disagree with you there. I have got 4 original OEM Ohlins MX6 sets and they all are exactly 400mm eye to eye. I even checked the workshop manual and it says 400mm too. I cant remember the exact stroke but im pretty sure its 145 or 147mm (metal to metal) with old body cap and 3mm less with the new 6 mm heigh body cap. I can check for you if its criticle.
Just checked my notes and i have measured 145mm for stroke and manual says collapsed length is 256mm so if thats taken off 400mm stroke is 144mm acording to the manual.  Thats with the old caps.
« Last Edit: June 04, 2010, 09:00:51 am by LWC82PE »
Offline Nitram
« Reply #3 on: June 04, 2010, 08:11:58 pm »
As I understand it the steel swing arm 250MX6 originally had the orange S&W shocks, 'though the 400s may have had Ohlins as an option.  The S&Ws measure 408mm centre to centre at full extension, and 270mm compressed against the rubber stops.  At least mine do, and I've got a stack of the horrible things !!
But the Operator's Manual does say 400mm so.............. buggered if I know   ;)
Nitram
Offline Canam370
« Reply #4 on: June 04, 2010, 08:50:36 pm »
 :-\ I'll measure again.
« Last Edit: June 04, 2010, 08:54:12 pm by Canam370 »
Offline Canam370
« Reply #5 on: June 04, 2010, 09:02:31 pm »
Go figure ; one set 400mm, one set 415mm. Both off MX6. I run 410mm when using Koni's. Steering is fine.
Offline Husky500evo
« Reply #6 on: June 04, 2010, 10:04:03 pm »
Thanks for the information guys. This has been very helpful.
« Reply #7 on: June 05, 2010, 11:09:43 am »
I had another look in the Canam workshop manual i got and it lists same eye to eye dimension and travel for the remote res Ohlins and S&W's on MX6's.The only difference the manual shows is that the distance between spring seats is less on the S&W's. The first part of the code on the Ohlins should be CA for Canam. I measured my bodies for reference sake and they are 229 with out cap.
