Author Topic: Finally!  (Read 12214 times)
Finally!
« on: June 02, 2010, 09:57:41 pm »
Today, I ended four years of searching, and bought a frikken TY175B. Its copped a 'modern' paint job with a white frame, all white tank, white fork lowers and black wheels - I never would have done it myself, but I can tolerate it for a ride bike.
Needs tyres, less god-awful wheels (the previous owner painted the whole lot flat black...) and a decent muffler (and I thought that trials bikes were supposed to be quiet!?).
First event is August, and its just down the road from home. :)
Anyhow, the questions are:
Where should I get new mudguards?
What rear shocks are recommended? The current ones are WAY too long (318mm is stock, most people run 340s - but I've got 385mm long shocks!).
Is there a preferred muffler?
TT
Re: Finally!
« Reply #1 on: June 02, 2010, 10:02:59 pm »
Cool! The older I get, the more I reckon a trials bike would suit me.  :-\
Knowing you, it would have been a bargain, so well done.  ;D
Got any photos?
Offline vandy010
  • #789 MX125a BMCC Brisbane
Re: Finally!
« Reply #2 on: June 03, 2010, 01:55:46 am »
bugger you Nathan.
i owned 3 Ty175's over the years and i just gotta get me another one.
what a ton of fun and the best wheelie machine i've ever owned. standing or sitting.
mine were always stock and that was good enough for me.
i'd probably go a later DT175 CDI set~up just to simplify things a bit and i remember the footpegs were made from some sponge like material.
mudguards?
i think DC do a set for the 175.
shocks?
the wreckers can help. {it's only trials after all}
preffered muffler?
the pipe is full of restriction. gut it if you like while keeping a similar shape/profile then a nice long silencer is good. one of my bikes ran a silencer from a YZ250J as they're reasonably long and quiet on the TY.
my 2 bobs worth.
"flat bickie"
DR
Re: Finally!
« Reply #3 on: June 03, 2010, 07:24:42 am »
Nathan, I wouldn't be without the RL these days ;D Goneli make unversal trials type front and rear guards (Don Newell sells them ;)) Not badly priced either but a bit of trimming maybe required to suit different makes. Could get you out of the poo till something more original comes along :-\ used to be a guy on fleabay (nsw I think) doing fibre glass replica's but I've not looked in ages.
SAABCOMBI
Re: Finally!
« Reply #4 on: June 03, 2010, 05:09:40 pm »
l am also very keen on trial, and with regrete l sold my Honda TLR 250, but in saying that, the fellow who bought it is having a ball riding it around the trials meeting in camberra. but l will buy another one day.
« Last Edit: June 03, 2010, 06:13:52 pm by DAVID#46 »
Re: Finally!
« Reply #5 on: June 03, 2010, 05:49:38 pm »
Best look up John Cane at www.tytrials.co.uk
He's a great source of parts & can supply a set of new betor gas shocks for under $200, I also bought a wes muffler for my 250 from him & it's nice & quiet & very nicely made
Another place to look is www.sammymillerproducts.co.uk  http://www.sammymillerproducts.co.uk/cgi-bin/showpage.fcgi
They don't list a front guard & unfortunately send stuff on fedex which is quick but pricey. Nice quality gear though
Re: Finally!
« Reply #6 on: June 12, 2010, 07:01:19 pm »
In this pic, I've added a handlebar cross-brace, new grips, moved the kilswitch and a couple of other things you can't see (made a cage for the airfilter, that sort of thing).
Funnily enough, the RM came with a quite good 18" Michelin trials tyre. Saved me buying a new one...
montynut
Re: Finally!
« Reply #7 on: June 12, 2010, 08:37:09 pm »
Nathan make sure that the rear tyre is the tubed type otherwise it will most likely not stay 'beaded up' on the old TY rims (unless they have been replaced with modern ones). The standard TY175B & C has very narrow rims (except the 'J' ADR version). Tyres are just as important or possibly more so in Trials even though most people don't seem to think so. The good trials tyres such as the Michelin go off very quickly and the side walls stiffen even though the tread seems soft.
Offline David Lahey
Re: Finally!
« Reply #8 on: June 15, 2010, 08:01:38 pm »
Hi Nathan
The WES end muffler is the best for sound quality, performance and weight
The standard fork tube setting has the tubes protruding 20mm above the top clamp
Budget shocks 340mm Betors with either 40 or 50 pound springs depending on how heavy you are.
High performance shocks Falcon Classic 340mm with 40 or 50.
Replica front guards are available in fibreglass in Australia and in plastic from DC plastics in USA - same as TY250 twinshock.
Good looking alternative front guard is Gonelli generic trials guard and fit it using Sammy Miller Products mount. Mount Gonelli with flap end at front and cut flap off in curve. Let me know if you want to see what this setup looks like and I will send you photos of mine.
Replica rear plastic guards available from a few UK suppliers and B&J Racing in USA
David Lahey
previous pseudonym feetupfun
Re: Finally!
« Reply #9 on: June 15, 2010, 09:57:44 pm »
Thanks gents.
I'm about 90~95kgs in my gear, so I assume I'll need the stiffer springs?
I did read someone advocating 360mm long shocks. Any input from you guys?
WRT the tyre/rim, its about to get a pair rims that are date stamped mid 1982, if that makes any difference. Still a 1.85" wide rear, same as the original that came off the bike. Provided it holds the bead properly, I'm happy enough to run the Michelin, even if it is past its prime - I'm sure it will be better than the 30-year old Dunlop that the bike came with...
Re: Finally!
« Reply #10 on: June 15, 2010, 10:17:45 pm »
These are popular with trials guys. http://www.rockshocks.co.uk/ Also you should find plenty of parts sources in UK's Classic Dirt Bike magazine
Another guy i would recommend for trials stuff is http://www.stevegoodemotorcycles.co.uk/ he has ebay shop too. Sells universal Stilmotor trials fenders and a heap of other stuff.
Offline David Lahey
Re: Finally!
« Reply #11 on: June 16, 2010, 08:17:12 am »
Yes some people fit 360mm shocks and run the fork tubes flush with the top clamp.
This gives more ground clearance but also changes the steering trail which in my opinion stuffs up the steering and increases fork flex.
Re: Finally!
« Reply #12 on: June 18, 2010, 09:06:36 pm »
OK...
So the bike is geared too tall at the moment (14-45 when stock was 12-49 [according to the parts manuals]).
I can replicate the 12-49 gearing by going to 11-45 using parts from my shed, BUT using a 520 chain.
Remembering that I'm a trials novice, am I really going to notice the extra weight of the 520 chain/sprockets over the 428?
Or is it worth me spending the extra money (that I don't have!) on new 428 bits?
Also, O-ring or non-O-ring chain?
Offline David Lahey
Re: Finally!
« Reply #13 on: June 18, 2010, 09:25:35 pm »
Yes 12-49 works pretty well in sections.
Where you might come unstuck is with clearance at the front sprocket. I haven't tried it myself and I don't remember ever seeing 520 chain used with those series 125/175 DT/MX/YZ/TY cases.
I think I might have a steel rear 428 you can have if you want for the cost of postage. I'll check what sizes I have if you want to go that way.
Aren't 520 and 428 the same thickness (weight) sprockets anyway?
Even if they are different by a few hundred grams you would probably not notice the difference in weight.
David
Re: Finally!
« Reply #14 on: June 18, 2010, 09:38:30 pm »
Thanks again. :)
The 520 front works on those motors.
My DT125 racer runs a 520 chain, and YZ125Xes were factory fitted with the 520.
Be happy to go with the 428 if your sprocket is a suitable size. I've got a new 13T (428) front here, FWIW.
O-ring or not?
