Author Topic: White Power 4054  (Read 8045 times)
Offline ba-02-xr
White Power 4054
« on: May 31, 2010, 04:04:26 pm »
Looking for the bump stop rubbers parte # 564.01.048.000. This is KTMs # not sure if it can be crossed to a White Power #.
Offline BAHNZY
Re: White Power 4054
« Reply #1 on: May 31, 2010, 07:08:46 pm »
NLA & if they were the would cost the better part of $100 for the pair. I had 2 x sets on BO for ages under both the KTM part and the WP part no. In the end I used a top out rubber from a later model Kawasaki fork. Not sure what part no or from what bike as they were left over bits from something. I have also been told that you can use the bump stop from an old school Ohlins piggy back, never went that route so not 100% sure.
Rod (BAHNZY) Bahn
Offline ba-02-xr
« Reply #2 on: June 01, 2010, 08:07:13 am »
Had a bit of a look , found a few  if still needed.
Yes How much. PM me a # to call you on & I will ring you ;D
Offline ba-02-xr
« Reply #3 on: June 08, 2010, 12:37:11 pm »
Thank you so much for your help Wasp. All bits I need.
Offline oldyzman
  • 250 two stroke!
« Reply #4 on: June 10, 2010, 09:44:25 pm »
Do the 4054 come std on the ktm? and what year if so... just a bit curious as i have some wp4054 on an old yammy...
oldyzman
Offline ba-02-xr
« Reply #5 on: June 11, 2010, 07:57:38 am »
84 495, 85 & 86 KTM, ATK. The screw in cap at the top should have a year & type of set up eg MX stamped to it.
Offline oldyzman
  • 250 two stroke!
« Reply #6 on: June 21, 2010, 08:46:48 pm »
Thanks for the info BA
Offline whitey 43
« Reply #7 on: June 27, 2010, 02:43:43 pm »
Hi Guys,can anyone tell me where I can get a set of bushes (fork) for some 40mm WPs? numbers stamped in the top are 58.23 & F61
Any help would be good,
                                Whitey
« Reply #8 on: June 27, 2010, 03:02:06 pm »
Try Forum Member on here "Wasp" www.suspensionshop.org
for assistance
Offline whitey 43
« Reply #9 on: June 27, 2010, 04:58:53 pm »
Thanks 4 that
