Author Topic: 500 Auto Workshop Manual & Beware of Threaded Rod  (Read 3226 times)
Offline PEZBerq
  • Brisbane
« on: May 29, 2010, 01:07:27 pm »
Ah the joys of buying blind.......Just received a 84 500AE to restore.  Pulled the engine down and discovered some genius decided to use threaded rod for cylinder studs instead of proper studs.  When they tightened the head they turned the studs and drove them through the bottom of the casting busting out into the magneto space   :o :o :o  Lesson - never use threaded rod as there is nothing to stop it turning and bottoming out in the blind hole - use correct studs i.e round bar with tapped ends!
I need to check if the con rod is usable.  Radial movement much less than 0.1mm.  Sideways rocking movement measured at top of rod is 1.7mm.  Does this sound usable? Replacement rods are rare as rocking horse shit and expensive. I have a NOS source at $430 + shipping. Recon source at $370 + shipping.
Does anyone had a workshop manual for the 500 auto?
Here are some photos of the busted thread and the cracked adjacent one. Is it worth attempting a repair (belzona?) or just leave alone. Welding would be asking for trouble. I guess there is enough thread left to secure the barrel and head.
Re: 500 Auto Workshop Manual & Beware of Threaded Rod
« Reply #1 on: May 29, 2010, 01:16:37 pm »
fix it up with devcon alloy putty it will help
« Reply #2 on: May 29, 2010, 01:29:01 pm »
Me personaly, I would TIG weld and retap hole on RHS and tig crack up up also.
Offline Kane Mcguire
« Reply #3 on: May 29, 2010, 06:11:19 pm »
tig and retap the way to go but there looks to be enough meat above the broken bit and the cracked side to helicoil or a threaded insert.
« Reply #4 on: May 29, 2010, 06:13:37 pm »
try husqvarna-parts.com, good prices etc.
« Reply #5 on: May 29, 2010, 06:55:39 pm »
Im pretty sure you would find a manual on the Husky Cafe Forum in the files section
also try www.repairmanual.com or http://www.husqvarnaoutlet.com/
