Author Topic: DR200 disc brake front end.  (Read 2050 times)
« on: May 22, 2010, 05:41:45 pm »
Set of forks, front wheel, and complete brake from a Suzuki DR200. There's also a white DR200 front guard if you want it.
The forks are 35mm diameter, so I figure they could be used as an upgrade for a DT175 or XT250 or something.
Forks are clean in the seal area, but have BAD rust between the triples - like lots of deep craters.
Wheel is OK - spokes are dull and a few are showing rusty spots, but its definitely usable. Still has the original (and awful) Bridgestone Gritty tyre.
Brake lever comes back to the bars, but everything seems intact. Disc is straight and not rusty.
$30 for the lot?
In Yass, southern NSW.
04000 23847
Re: DR200 disc brake front end.
« Reply #1 on: July 30, 2010, 05:58:58 pm »
Still here - will goo in the next scrap metal run (probably next Wednesday) if not sold before then.
Offline suzuki27
« Reply #2 on: July 30, 2010, 06:35:54 pm »
The internals of these forks can be used to really improve the action of a lot of pre-75 forks- so I hear .
« Reply #3 on: July 30, 2010, 11:27:33 pm »
nathan
if you scrap them i want the disc and calaper for the back brake on my slider
jim
Offline Tex
« Reply #4 on: August 07, 2010, 09:57:12 am »
Did you end up getting rid of this Nathan?
« Reply #5 on: August 07, 2010, 09:58:58 am »
Still here, although MX250 has put his hand up for it (he's got some other bits here too).
