Author Topic: How much oil - 1980 C125  (Read 4342 times)
Offline spicydave
« on: May 15, 2010, 09:38:45 pm »
How much engine oil does a 1980 CR125 take
Heinrich
Offline spicydave
Re: How much oil - 1980 C125
« Reply #1 on: May 17, 2010, 04:12:45 pm »
Anyone?
If someone have a electronic Service Manual that is willing to email me I'll appreciate
Heinrich
ianscr250
« Reply #2 on: May 18, 2010, 12:39:20 pm »
for memory about 900 mills of oil in the donk
090
« Reply #3 on: May 18, 2010, 06:00:49 pm »
I haven't found out either. There is an oil level bolt on the clutch cover.
Offline spicydave
« Reply #4 on: May 18, 2010, 06:13:03 pm »
Yip - I have filled 500ml and opened the level screw until it stopped dripping
Not much came out so I assume the level is at about 490ml
« Reply #5 on: May 18, 2010, 06:33:21 pm »
700mls. That's straight from the genuine Honda owners manual.
Offline spicydave
« Reply #6 on: May 18, 2010, 08:13:52 pm »
Can I just pop in anothr 200ml?
« Reply #7 on: May 18, 2010, 08:20:33 pm »
I guess you could assuming it was completely empty when you put the 500mls in.
Offline spicydave
« Reply #8 on: May 18, 2010, 09:39:38 pm »
Yes JohnnyO - I drained the oil and then filled the 500ml
« Reply #9 on: May 18, 2010, 11:04:02 pm »
there is a difference in fill volumes based on doing an oil change (smaller amount) and refilling after a case split or open (larger amount).  Which one did you do?
Offline spicydave
« Reply #10 on: May 19, 2010, 02:33:21 am »
Thanks guys
I poped in another 200ml and started the bike
Let it ran for a while and cold down
Opened the inspection screw and a tat bit came out
So I assume we at around 700ml and the correct as per the manual JohnnyO as said
