Author Topic: Wanted: Mikuni Jets  (Read 2084 times)
IT400C
Wanted: Mikuni Jets
« on: May 12, 2010, 01:27:14 pm »
Anyone got a NOS 370 main jet and Q-0 Needle Jet for a VM38SS Mikuni?  They should be the standard jets for the YZ400C.  I can still buy them new, but would prefer to buy of forum members if possible..   ;D
38mm Mikuni
Main Jet / Pilot Jet - 370 / 60
Needle Jet / Jet Needle-Clip position - Q-0 / 6F16-3
Slide Cutaway  - 3.0
Float Level - 18mm
Mixture screw - 1 1/2 turns out
Everything else should be the same as my IT400C...
Re: Wanted: Mikuni Jets
« Reply #1 on: May 12, 2010, 02:14:44 pm »
YEs i do, or i can get them for you new off Ian williams tuning who sponsors me, which is close enough to a forum member ?  huh  ;D
also if the other stuff you need isnt the same he carries ALL the mukuni PArts and consumables anyway.   ;)
also consider the Dh needle as the f is a little bit power point
« Last Edit: May 12, 2010, 02:18:18 pm by Freakshow »
IT400C
« Reply #2 on: May 12, 2010, 02:18:40 pm »
cool - can you let me know how much?
« Reply #3 on: May 12, 2010, 04:41:51 pm »
pm'd
All Things 414
« Reply #4 on: May 12, 2010, 05:49:02 pm »
How do we get in touch with this Ian Williams Freaky?
« Reply #5 on: May 12, 2010, 06:31:15 pm »
http://www.iwt.com.au/
Just be careful because many of the OEM Yamaha/suzuki Mikuni parts are specifically made for them and are different to aftermarket mikuni parts.
« Reply #6 on: May 12, 2010, 07:28:24 pm »
T.D. Hatrick in Townsville are also great suppliers of Mikuni jets for flat slide and round slide carbys.
Ph 07 47712677
« Reply #7 on: May 13, 2010, 03:04:56 pm »
naH Reckon THATS SUZUKI YOUR THINKING OF leith
most of the Yams use the standard stuff, anyway i know he has all the stuff for PRe 85 Yamas on the shelf, cause we use them all the time,
Guys Just Tell him you spoke to Kerry and he will look after you for sure. ;)
« Last Edit: May 13, 2010, 03:13:05 pm by Freakshow »
