Author Topic: front number plate bracket's  (Read 7833 times)
« on: May 09, 2010, 05:26:31 pm »
This Was made for a Rm 125 B , but could be used on other bikes.
Started with a piece of aluminium C section  32x25x3 thick and  cut a piece 62 mm long.  Then made a mark @ 17mm in from top and a centre line @ 31 mm ( as shown )
Next you will need a 35mm hole saw ( for 36mm forks ) and a piece of timber - put the bracket & timber in a drill vice and clamp together - run your centre line down on timber and measure a future 18mm down from your 17mm mark and this will give you your pilot drill centre .    ( time for a cuppa as I'm a slow typer )
Re: front number plate bracket's
« Reply #1 on: May 09, 2010, 05:43:01 pm »
Drill all the way cutting top and bottom , making sure that work piece is square with drill.
Ooops forgot to tell you to mark  2 holes either side of centre line @ 22mm and 15mm down , drill size 6mm drill thru both sides.
Grab a grinder or hacksaw and cut  sections out as shown...... 45 degree cut & a square cut that lines up with back of holes.
« Reply #2 on: May 09, 2010, 05:47:54 pm »
Clean  up all edges and round off as required to suit your tastes...........
« Reply #3 on: May 09, 2010, 05:53:44 pm »
Finished artical mounted using pop rivets along with washers ( 4.5mm)   # side and  with a piece of inner tube to fasten it to fork tubes.
« Reply #4 on: May 09, 2010, 06:11:49 pm »
Nice work Oldfart. Do you know if Titanium is available in the same section? Jerry
« Reply #5 on: May 09, 2010, 06:12:50 pm »
very nice indeed Stu, you're wasted as a plumber :o ;D
Ji Gantor
« Reply #6 on: May 09, 2010, 06:49:58 pm »
Hi Stewart,
That is a great post, well done.
Every VMX bike needs a front number plate holder and that is a great design.
Ji
Offline pmc57
« Reply #7 on: May 09, 2010, 08:00:32 pm »
Stewy,
That's a great design and so easy to make, they're nearly as good as the "4mm tent peg front brake cable guide" idea. I have to ask, where oh where did you come up with the idea for this one, I'm truely amazed?
Well done Stew, your photography work is exceptional and provides great detail, and well worth passing on to fellow VMX'ers.
Offline lukeb1961
  • PE175N, RM80B, JR50C
    • PE175N
« Reply #8 on: May 10, 2010, 06:47:19 am »
or if you don't have the time, these might do the trick.
http://www.vintage-suzuki.com/products000029r_hardware.htm
(taking nothing away from the elegance and simplicity of Stewarts great work!)
« Last Edit: May 10, 2010, 07:15:32 am by lukeb1961 »
Offline bazza
« Reply #9 on: May 13, 2010, 05:24:27 pm »
 STU you have come along way from using #8 fencing wire at jeffersons farm and mangere Mountain !!
Embrace patina
« Reply #10 on: May 13, 2010, 05:41:51 pm »
You forgot one important part there Bro.....you need to put electrical tape around the fork to stop the bracket from wearing away your hardchrome!!!....now show me how you are going to make the tape? ;D......tipical smartarse plumbers....always doing half a job.....still charge the full amount though....not a bad job for a jaffa.
« Reply #11 on: May 13, 2010, 06:30:49 pm »
Bazza, Did you Ride last weekend ???
Crocka shit, Ah duct tape I completely over locked that. But as you can see in close up view top part of forks are pitted
 ;D
Offline bazza
« Reply #12 on: May 14, 2010, 04:41:01 pm »
 No mate, good turnout.My old man had a stroke sat night and we were at hospital, hes just home today and seems chirper. However i am doing lots of trips to the Flying Jug,drinking Leon Rouge to get in trim for C/D, see you soon mate.
Embrace patina
« Reply #13 on: May 14, 2010, 04:46:26 pm »
Godd to see your dad on  the improve Bazza.
« Reply #14 on: May 17, 2010, 08:37:51 pm »
Stu forgot to mention the performance gains to be had by installing a set of his OF Plate Brackets tm. Having a set fitted to his RM 125 allowed him to blitz the field in the last race I saw him in.
