Author Topic: CZ spoke lengths  (Read 3381 times)
CZ spoke lengths
« on: May 08, 2010, 08:06:21 pm »
does anyone have any CZ rear wheel spokes lying around that they're able to measure for me? The hub I've got is late mid 60's -early 70's.
Ji Gantor
Re: CZ spoke lengths
« Reply #1 on: May 08, 2010, 10:21:24 pm »
I have a brand new set of stainless steel HD spokes and nipples for a 1973 rear wheel if that helps.
Ji
« Reply #2 on: May 09, 2010, 09:36:04 am »
thanks mate, is yours the same as this one?
Ji Gantor
« Reply #3 on: May 09, 2010, 09:38:02 am »
It looks the same as mine.
Ji
« Reply #4 on: May 09, 2010, 09:48:29 am »
Cool, any chance I could get you to measure some spokes when you get the time?
Ji Gantor
« Reply #5 on: May 09, 2010, 09:50:11 am »
Sure, are you going to have some made.
Ji
« Reply #6 on: May 09, 2010, 10:04:39 am »
I was going to try and buy some off-the-shelf. Always easier if you know what you need, rather than relying on the person you're buying them off.
You ended up getting yours from Titmans didn't you?
« Reply #7 on: May 09, 2010, 10:11:12 am »
74 parts book says LH M4x199  RH M4x147, should be the same looking at that hub. I don't know if the early ones with the riveted sprocket like I've got are different
Hope this is a help
« Reply #8 on: May 09, 2010, 10:51:15 am »
cheers tony,
I'm assuming those measurements are from the end of the threaded section to the start of the bend? and they'd all be the same 45 degree bend?
« Reply #9 on: May 09, 2010, 11:22:07 am »
My guess would be from the bend to the end, list only gives left & right lengths with the wheel needing 18 per side. Went out to garage & did a quick check on the earlier wheel, looked like those numbers were about right. Couldn't be sure on the bend but 45 degrees probably isn't too far out
« Reply #10 on: May 09, 2010, 12:56:23 pm »
beauty, thanks mate.
Offline NR555
« Reply #11 on: May 10, 2010, 10:02:50 am »
My 2 cents:  Charlie Richardson from CR High Performance in the US sells sets of custom tapered Buchanan spokes for CZ rear wheels.
I was cracking hubs every other race until I started running them.  Apparently the taper allows just enough flex to take a bit of stress away from the magnesium hub.  Completely fixed the problem for me.
www.crhighperformance.com
