Author Topic: MX 125C  (Read 2163 times)
TM BILL
MX 125C
« on: May 08, 2010, 07:35:19 am »
Can somone tell me what other pistons i can use in my MX 125C thanks Bill
Offline vandy010
  • #789 MX125a BMCC Brisbane
Re: MX 125C
« Reply #1 on: May 08, 2010, 07:48:20 am »
treat it the same as a YZ/DT of the same era Bill.
anything up to 1982 should work.
a piston kit is far better than buying a piston and rings seperately as yamaha did experiment with differing ring combinations {ring thickness,single/double etc}.
if your after performance, most YZ pistons will have a nice cut away on the inlet.
or go the DT's full skirt if you want something a little more mellow and reliable.
Davey will probably be along soon  ;D sprooking off about them woosner things...
might catch you at CD7,
cheers mate.
"flat bickie"
TM BILL
Re: MX 125C
« Reply #2 on: May 08, 2010, 08:12:02 am »
Thanks Mick  :) will catch upat CD 7 for sure .
I have booked DJ and me flights so were on  ;D
Re: MX 125C
« Reply #3 on: May 08, 2010, 06:32:54 pm »
What size you need Bill ?  i have a few sets here in differant sizes single and double ringers
Offline oldyzman
  • 250 two stroke!
Re: MX 125C
« Reply #4 on: May 09, 2010, 09:22:31 pm »
Gday Vandy,
I noted that cutaway on DT pistons that i had for another project.  but it would seem that it would fit my yz125e. I was told i could cut the dt piston the same as the yz, would it matter i aired on the side of caution and only  cut away 90% or so. might give a bit more mid range???
Cheers Brett
Offline vandy010
Re: MX 125C
« Reply #5 on: May 10, 2010, 08:10:12 am »
i've never really ventured down the path of cutting piston skirts myself but i do know the DT style pistons have a hell of a lot of meat on them by comparison to the YZ ones.
they look strong enough to handle a bit of a skirt trim is what i mean.
i'd do it if it's all i had to work with.
"flat bickie"
