Author Topic: what this 83/490 spider worth  (Read 4730 times)
Offline paul
« on: May 05, 2010, 06:02:02 pm »
Offline paul
Re: what this 83/490 spider worth
« Reply #1 on: May 05, 2010, 06:46:51 pm »
Frame - good condition
Swingarm - good condition
Front Forks - good condition (no rust)
Wheels - good condition
Engine - Good condition, no cracks in fins, turns over and has compression
Rear Shock - good condition, not original I think it is a Works Performance.
Things needing attention :
Gear shift lever is bent on the tip and probably needs replacing
Footpegs are a little out of shape but could be straightened
Needs exhaust
Needs small alloy weld on RHS case see picture.
Rear brake rod not original
Offline paul
« Reply #2 on: May 05, 2010, 06:56:13 pm »
yes  e47   i know 3.00 dollars
Offline paul
« Reply #3 on: May 05, 2010, 07:02:56 pm »
Offline paul
« Reply #4 on: May 05, 2010, 07:04:47 pm »
damaged case
Offline E74
« Reply #5 on: May 05, 2010, 07:12:11 pm »
300
Offline paul
« Reply #6 on: May 05, 2010, 07:16:53 pm »
300
whats happen e 47 you in a good mood ::)
Offline frostype400
« Reply #7 on: May 05, 2010, 07:35:19 pm »
more than 300 surely what a beast are all the boxes in the background maico bits ;D what is it worth do you know???  Thanks Michael. :)
1971 tm400 and PE's
Offline paul
« Reply #8 on: May 05, 2010, 07:41:02 pm »
im thinking off tradeing it for another bike ,
« Last Edit: May 06, 2010, 08:35:43 am by paul »
Offline Stevo17
« Reply #9 on: May 07, 2010, 06:49:40 pm »
What would this Spider be worth here in Oz ?
« Reply #10 on: May 07, 2010, 07:00:14 pm »
What's a dual control monoshock - controls suspension both up and down?
Offline Stevo17
« Reply #11 on: May 07, 2010, 07:01:43 pm »
dunno, thats what they called it after the alpha 1... supposed to be much better than the alpha
Offline paul
« Reply #12 on: May 07, 2010, 07:31:44 pm »
at least 4k
