Author Topic: Ikon Shocks  (Read 3781 times)
Evil Rudy
Ikon Shocks
« on: May 03, 2010, 09:21:23 pm »
Anyone got the skinny on Ikon shocks? Got a pair? Happy? Sad? Indiffernt? Value for $?
Any help apreciated.
ER
Re: Ikon Shocks
« Reply #1 on: May 03, 2010, 10:36:22 pm »
The ones i've seen have been crap.
No rebound damping, wrong spring rates and were supposedly built to suit that particular bike.
Buy something else...
Re: Ikon Shocks
« Reply #2 on: May 03, 2010, 10:42:28 pm »
Im pretty sure the editor of VMX mag has them. i guess it really depends on what bike they are going on. i wouldnt use them on anything that has long travel suspension with shocks angled forwards.
Offline matcho mick
    • Moto Tumbi
Re: Ikon Shocks
« Reply #3 on: May 03, 2010, 10:43:31 pm »
got them on 4 of my bikes,i'm pretty happy with them, :P
oops,they're konis,but arn't they the same, ::)
« Last Edit: May 03, 2010, 10:45:13 pm by matcho mick »
Evil Rudy
Re: Ikon Shocks
« Reply #4 on: May 03, 2010, 11:11:36 pm »
keep 'em comming?
Re: Ikon Shocks
« Reply #5 on: May 03, 2010, 11:24:45 pm »
I put some on a leading link i built for a road bike sidecar a few years ago. Hasnt been any complaints. Their sales/service is very good.
Offline vmxken
Re: Ikon Shocks
« Reply #6 on: May 04, 2010, 06:31:05 am »
Yes, I have a pair I've used on both my KX450 and KX125.  They are the alloy-bodied, gas-charged units, with the threaded preload adjustment.  In short, I've found them to work well.  They are quite expensive (high $600 if I recall correctly) but they are a quality unit.  The spring rate I received was perfect.  Their other advantage is that despite being alloy-bodied, gas-charged etc, they still look right on a pre '75 bike, mounted in the conventional 'right way up' position.
Regards
Ken
shoey
Re: Ikon Shocks
« Reply #7 on: May 04, 2010, 07:35:03 am »
I had a set on my 79 440 maico a few years back and they worked well.
Re: Ikon Shocks
« Reply #8 on: May 04, 2010, 08:11:00 am »
Both the guys i know that had Ikons have since bought better shocks. They were fitted to evo bikes and didn't work as well as they should've.
Re: Ikon Shocks
« Reply #9 on: May 04, 2010, 08:39:07 am »
Had the steel bodied model with adjustable rebound  on a couple of pre'75 bikes and they were good. Would but them again no problems.
Offline shorelinemc
  • life sucks&then you die
Re: Ikon Shocks
« Reply #10 on: May 04, 2010, 09:00:20 am »
i run a set on the back of my wasp mx outfit runs a gs1000,with bike rider,passenger weighs around 400kg
and have had no probs i am going to put a set on the front as well hope this helps
Offline HL500
Re: Ikon Shocks
« Reply #11 on: May 04, 2010, 10:10:46 am »
I have them on the back of my PE400.  He build them to the same dimensions as the originals.  They seem to work well.  The only issue I have is a cosmetic one.  You cannot mount them with the shock body upwards as the rebound fails.
