Clubroom
Tech Talk
cr250
Topic: cr250 (Read 2798 times)
cagiva125
cr250
April 24, 2010, 06:27:44 pm »
Hi i have a cr250 and have gear shaft problems the shaft slides when out all gears are there but when slides in looses all gear,any ideas?thanks..
JohnnyO
Qld
Re: cr250
April 24, 2010, 06:52:53 pm »
There should be a lug in the sidecover to stop the shaft from sliding in and out.
When it slides in it probably disengages from the selector mechanism.
oldyzman
250 two stroke!
Re: cr250
April 24, 2010, 09:52:05 pm »
Hey Gagiva, what model cr is it?
cagiva125
Re: cr250
April 25, 2010, 09:04:59 am »
Thanks mate pulling side cover of today..
cagiva125
Re: cr250
Reply #4 on:
April 25, 2010, 09:06:59 am »
still not sure on year model,but thinking late 80"s early 90,takeing frame numbers to honda tuesday,thanks again,
cagiva125
Re: cr250
Reply #5 on:
April 25, 2010, 11:35:40 am »
ok pulled side cover of today noticed the lug on casing looks worn but unsure how long it should be its approx 15mm long the kickstarter lug that holds spring in place is 20mm hope someone can help with my dodgey description thanks
Hoony
Melbourne, Vic.
Re: cr250
Reply #6 on:
April 25, 2010, 07:10:46 pm »
i am assuming this bike is Honda CR250 ( not Husky CR250). we can probably identify the model with some key info if you reckon its late 80's
is it have rear disc? (yes = 1987 onwards)
does it have low boy pipe? ( yes = 1988 onwards)
does it have upside down forks? ( yes = 1989 onwards)
can you post any pics or email them?
Long time Honda Fan, but all bike nut in general, Big Bore 2 stroke fan.
http://www.youtube.com/watch?v=XJoKP6MawYI
Clubroom
Tech Talk
cr250
