Author Topic: Cheney JBR progress  (Read 6598 times)
Offline Marc.com
Cheney JBR progress
« on: April 18, 2010, 01:22:41 pm »
kinda like this one, have gung ho square barrel motor for it, good pre 75, get away while the CRs are blubbering on the line
Re: Cheney JBR progress
« Reply #1 on: April 18, 2010, 03:31:33 pm »
Is it the angle of the photo or are those shocks a bit longer than normal? My Cheney has basically the same frame geometry and I'm using 345mm Arnaco shocks which is the length reccomended by Dodgy Simon.  How long are yours Marc?
« Reply #2 on: April 18, 2010, 05:26:38 pm »
Mark , it's because they are opposite  ;)
Offline bazza
« Reply #3 on: April 18, 2010, 06:17:35 pm »
I like it a comment from stu at last i have proof he is going to the dark side,look forward to catch up at C?d Stu.
Embrace patina
Offline Marc.com
« Reply #4 on: April 18, 2010, 06:43:58 pm »
Yeah I am going for the inverted shock thing, not sure there length Firko, this frame has more the same shock positions as the 74 CCM, than some other JBR frames I have seen.... I like it
Offline JC
« Reply #5 on: April 19, 2010, 08:24:19 am »
Nice. Often wondered how the poms rode em tho w the footpegs so far forward.
Offline Marc.com
« Reply #6 on: April 19, 2010, 11:28:05 am »
If you watch some of the old timers, a lot of them rode them hanging way off the back, or sitting in the seat, guess footpeg postions have changed a lot over the years.
Offline Marc.com
« Reply #7 on: May 02, 2010, 11:33:40 pm »
this is the motor that will finally go in it, just need to get it seriously assembled. Will do the Carillo rod and PMS clutch, but rest of motor will be relatively mild.
Oppet
« Reply #8 on: May 03, 2010, 01:03:58 am »
Nice, are those PES sides? And what is PMS clutch?
I have new PES clutch, that I can recommend, nice and smooth
TM BILL
« Reply #9 on: May 03, 2010, 06:27:24 am »
Once a month it becomes unpredictable and you cant use it  ;)
Offline Marc.com
« Reply #10 on: May 04, 2010, 10:23:01 am »
 ;D ahem PES, must have been feeling a little tension in the air when I was typing. ::)
