Author Topic: getting old stickers to stick.  (Read 4976 times)
« on: April 16, 2010, 12:31:20 pm »
As a final touch to my upcoming bike I'd like to use some rare, oldschool stickers I've removed from various bikes over the years. Naturally the sticky side doesn't stick any more so does anybody have a good idea for resticking them? I've tried various commercially available glues and silastic but in most cases the sticker ends up bubbling and not adhereing properly.
 Over to you Brains Trust. ;)
Offline Billet YZ
  • Melton Victoria.
Re: getting old stickers to stick.
« Reply #1 on: April 16, 2010, 12:40:18 pm »
G`day Firko,
                 i have in years gone past used a double sided tape that was approx. 2" inches wide and as thin as masking tape, i would try to use some of that and stick it to the back of your old stickers. Otherwise there is the narrower version approx. 10 mm wide double sided tape that is easy to get and also very thin, just means putting it on a strip at a time until the back of the sticker is covered.
        Peter.
Offline BAHNZY
« Reply #2 on: April 16, 2010, 01:07:42 pm »
Firko, if they are good quality have them scanned and converted to a Photoshop or Corell file where they can be reproduced using state of the art substrate printing and they will last forever.
Rod (BAHNZY) Bahn
« Reply #3 on: April 16, 2010, 01:39:13 pm »
Thanks guys.....Rod, I had some stickers reproduce once and they either faded in anything brighter the garage fluro or the ink washed off when I washed the bike. I've been told things have improved a bit since then but that experience made me a bit shy of going the repro route. I'll look into it. Ditto the sticky tape idea.
Offline BAHNZY
« Reply #4 on: April 16, 2010, 02:10:43 pm »
Firko,
I can do the artwork and i have had a good run with NineTwoDecals in Queensland.
Let me know what you want to do.
Rod
Rod (BAHNZY) Bahn
« Reply #5 on: April 16, 2010, 02:22:18 pm »
Firko you know the round Bultaco stickers on the Bulty fuel tanks. I got some repo ones from Peter Schoene. They sit 1.5-2.0 mm high. Sensational quality, dont fade, dont wash off and stick like shit to a blanket. Suggest you ask Peter where he sources them. Maybe they can make some for you. Cheers Jerry
Offline suzuki447
« Reply #6 on: April 16, 2010, 10:11:56 pm »
hifirko,i put all my tank stickers on with glazing silicone ,smear on to tank with putty knife 1 mm thick then place sticker on and gently smooth out with knife to make flat ,i also punch small holes in decal like mxm sticker which lets them breath ,my 82 rm125 and 250,s have tank stickers that have been on for 4yrs without an edge lifting hope that helps ,don.
bikes in shed.74tm125,76,78,82rm125s,...82,83rm250s.80canam qualifier.80,83yz125s.86yz490.80it125.76it400.80pe175and250.79rm50.76xr75.2xpuch50 magnums.jawa speedway.72honcho 90.84xr200.87xr100.phew thats all.
RMJJ
« Reply #7 on: April 17, 2010, 07:18:27 am »
I've used nail polish / varnish to stick edges down. works well but don't know how
it would work on a whole sticker.
It was the wife's polish btw not mine.
suzuki43
« Reply #8 on: April 17, 2010, 07:32:20 am »
Yeah yeah JJ we believe you ;)
Offline E74
« Reply #9 on: April 17, 2010, 08:12:31 am »
I have a 3m product that will put new adhesive on the sticker with backing paper and all, just like it was brand new, exactly what you need mark, drop them over and I will do them all for you.
« Reply #10 on: April 17, 2010, 09:28:19 am »
Thanks Darren...that's the stuff I'd been searching for since I someone mentioned it on some other forgotten forum a couple of years ago. I'll drop you a line, it's a good opportunity to check out the Magoo Bar as well!
Thanks also to the rest of the suggestions fellas....I'll actually try 'em all to see what works and what doesn't. Keep 'em coming.
« Last Edit: April 17, 2010, 09:31:56 am by firko »
Offline lukeb1961
  • PE175N, RM80B, JR50C
    • PE175N
« Reply #11 on: April 22, 2010, 09:37:50 am »
is that this sort of thing?  3M™ Adhesive Transfer Tape 467MP
http://solutions.3m.com/wps/portal/3M/en_US/Graphics/Scotchprint/Prod-Info/Catalog/?PC_7_RJH9U5230GE3E02LECIE20S7M3_nid=7JWNWBXPKVbe2X45PZSQV2gl
Luke
Offline E74
« Reply #12 on: May 05, 2010, 07:49:00 pm »
The product is Scotch 3M 468MP Hi Performance Adhesive and is a little thinner than the 467MP
