Author Topic: 1974 Yamaha MX 175  (Read 3580 times)
Offline DCPlasticsguy
1974 Yamaha MX 175
« on: April 14, 2010, 11:04:33 pm »
Can I use a wiseco piston from a 1976 Yamaha YZ 175 in my MX 175 cylinder? The wiseco part number is 374M06750. It
would allow me to go over a few sizes from the oem yamaha pistons. Also, Wiseco shows a piston for the 78-82 DT 175 and CT2/CT3 175 models. That part number is 471M06750. The pin and bearing sizes would both work. Please let me
know if anyone has done this.
Offline vandy010
  • #789 MX125a BMCC Brisbane
Re: 1974 Yamaha MX 175
« Reply #1 on: April 15, 2010, 01:26:14 am »
Nathan should be along any minute now.........
i'm not too up to speed with the 175's but a 76" piston kit into a 74" on a 125 is done everyday and not a problem. the porting hasn't changed enough to require a new piston set~up so i'd be happy with the 76" wiseco kit.
i'd reckon the later would also work as in the 125's, i think up to 82 are all interchangable as long as you have the right rings for the right piston as there are some different ring configurations between the pistons.
buy a whole piston kit if you can.
"flat bickie"
« Reply #2 on: April 19, 2010, 12:30:57 pm »
YEp just check that your using the iron bore rings ( one listed in Wiseco next to the MX rings)
