Author Topic: cagiva 1983 125  (Read 2473 times)
cagiva125
cagiva 1983 125
« on: April 09, 2010, 02:16:55 pm »
Hi can any one help me,i cannot find a oil seal the one that goes behind the front sprocket for my wmx125 1983 cagiva,no one in aus,seems to have one i thought this would be a great project but very hard to find parts thanks for any help,(i should of just kept my yz250g but sold to kevwrx,that one i will regret..
maicoman
Re: cagiva 1983 125
« Reply #1 on: April 09, 2010, 02:44:59 pm »
Have you tried Huqvarna for parts, seeing that Cagiva bought out Husky and Ducati that bought Cagiva. I'm not sure how it goes but when I used to buy my Husky parts they can in a bag with all those names on it. You could also get the seal specially made aslong as you have a sample. Good luck with the search.
cagiva125
Re: cagiva 1983 125
« Reply #2 on: April 09, 2010, 02:56:45 pm »
Thanks mate,i was thinking of getting one made up but the previous owner pulled it out and through it away,so i dont have one to go of,called the local husky dealer but they told me they only go back to 93,even tried the cagiva parts inporter but still no luck but im determind to get one its the only thing i need,,
Re: cagiva 1983 125
« Reply #3 on: April 09, 2010, 03:38:01 pm »
Normally if you can supply outside diameter, inside diameter & depth/thickness measurements they should be able to do something without a sample.
Which dimension is causing the problem size wise, you can always make a sleeve for the outside or inside to adapt a readily available seal if need be
Re: cagiva 1983 125
« Reply #4 on: April 09, 2010, 11:27:27 pm »
as Tony said, your local bearing shop should be able to help. Take as many measurements as you can of where the seal should go.
« Last Edit: April 10, 2010, 10:27:43 am by mainline »
cagiva125
Re: cagiva 1983 125
« Reply #5 on: April 10, 2010, 09:12:48 am »
Thanks guys ill be measuring it up this weekend and hopfully the bearing shop can help me out,projects were never meant to be easy!
cagiva125
Re: cagiva 1983 125
« Reply #6 on: April 10, 2010, 10:01:34 am »
just called the bearing shop with my measurments,and guess what they have that exact seal,picking up tuesday thanks again..
