Author Topic: Is this what i hope it is??  (Read 2938 times)
Offline RED ALERT
« on: April 08, 2010, 11:05:25 pm »
I was collecting some parts from a friend to fix up my 250R, when he asked me if I knew what the the head and barrell on the right was off.
We agreed it looked big bore Honda and I took it home to compare with my 480 (on the left). After having another look at Caps 480 resto,
I'm pretty sure it's a Mugen kit. The piston in it is maybe 2.5 - 3mm smaller than a 2nd oversize 480 piston, so is it a 450 or 480??
I really want to keep it. :)
« Last Edit: April 09, 2010, 07:28:33 am by RED ALERT »
Offline cyclegod
  • Sunny PERTH W.A
    • cyclegod on "youtube"
Re: Is this what i hope it is??
« Reply #1 on: April 09, 2010, 12:26:59 am »
Ban BLACK rims NOW
Offline motomaniac
« Reply #2 on: April 09, 2010, 08:25:59 am »
If its Mugen it will have mugen cast on it somewhere , if not its a Honda issue works part which is same as Mugen but without the name casting.Its 460 for sure.Whats the bore like?
[/img][/img][/img]
Offline RED ALERT
« Reply #3 on: April 09, 2010, 08:55:04 am »
Thanks guys,
Moto, the only markings on the barrell are underneath the reed flange, it's stamped 'B  21'
Will take some more shots when I get a chance, cheers.
mcmuffin
« Reply #4 on: April 09, 2010, 09:01:33 am »
if its an 89mm piston its a 480 mugen kit worth around 2k
Offline caps 999
« Reply #5 on: April 17, 2010, 03:33:00 am »
It's a 460 kit same as the one I'm runing on my 480 if you look at the base of the barrel there will be a vent toward the back of the barrel to run this kit on a 480 you will need to get that welded
MUGEN power
