Author Topic: CR390 shock length  (Read 2681 times)
CR390 shock length
« on: April 08, 2010, 05:16:29 pm »
Can anyone help with the correct standard length of 1977 CR390 shocks please? These are different to '77 360 as the frame mounting points are different. Also seeing the VMX rules state that the travel must be limited to 9" on this model to be legal for pre'78 (even though it was 10" standard in 1977), what length shock would bring it back to legal. The bike I have has no shocks and my literature gives part numbers, not specs. Any help appreciated.
TT
Re: CR390 shock length
« Reply #1 on: April 08, 2010, 05:26:29 pm »
I'll check through the info I've got tonight for the shock measurement.
FWIW the way I limited travel on my '77 390CR was with larger bump stops. Cheap and easy.
Ok, a note in the front of the owners manual says 15" eye to eye and the Works Performance site agrees with that.
Unless someone else has better info?
« Last Edit: April 08, 2010, 05:31:18 pm by Tony T »
Offline motomaniac
« Reply #2 on: April 08, 2010, 05:44:32 pm »
77 360? So thats a Mikkola rep inline fork model .those are 13.5"
The 77 390 next generation longtravel bike with leading axle forks are 15".
Got some gen Husky Ohlins there if you need K
« Reply #3 on: April 08, 2010, 08:58:16 pm »
15" remote reservoir Brent?
