Author Topic: DT2MX Shock Length  (Read 3340 times)
TT
DT2MX Shock Length
« on: April 08, 2010, 01:42:46 pm »
Can anyone offer advice on the eye to eye shock length on a '72 DT2MX, please?
Re: DT2MX Shock Length
« Reply #1 on: April 15, 2010, 08:15:08 pm »
probally a thermal shock and they normally where 330mm
Offline JC
« Reply #2 on: April 17, 2010, 08:07:27 am »
DT2Ms didn't run thermal flow shocks, just the original chromed jobs, but they could have been 330mm. I checked a Koni list I have but it didn't list them for DT2M
« Reply #3 on: April 17, 2010, 09:23:02 am »
i think i have a set in the shed
all chrome 2 spring shocks is that them
« Reply #4 on: April 17, 2010, 09:39:40 am »
In oldspeak, I think 13.5" will be pretty close Tony.
TT
« Reply #5 on: April 18, 2010, 10:34:28 pm »
Thanks gentlemen, I haven't even got the bike yet but I found a set of shocks that I thought might suit.
They will.  ;D
Offline JC
« Reply #6 on: April 19, 2010, 08:17:01 am »
I just checked the Yamaha Superlight article in Cycle World, which was based on an RT2M. They used girling shocks for Huskies (just under 12") which were said to be 1" shorter than standard, which would make the originals pretty close to Freaky's 330mm (13") if you want original length. But I'd be running something a little longer myself.
« Reply #7 on: April 19, 2010, 12:28:58 pm »
Tony, next time your passing drop in , ill show you the differance on the DT2 vs the YZa.  the only bit you need worry about is 4" .
