Author Topic: 80cc reed block  (Read 3016 times)
Offline k2000x
80cc reed block
« on: March 14, 2010, 05:56:03 pm »
just got a cr80 v-force reed block for 99c thanks 2 ebay i was toying with the idea to use on a 250 montesa engine would it be to small, would that make it have more torque. i think it would work as they only have a small intake manifold to start with....what do you guys think
Re: 80cc reed block
« Reply #1 on: March 14, 2010, 08:03:52 pm »
Is the engine a reed  or piston port?
Offline k2000x
Re: 80cc reed block
« Reply #2 on: March 15, 2010, 06:40:38 am »
its only piston port...i was going to make a manifold and weld it to the cylinder.
Re: 80cc reed block
« Reply #3 on: March 15, 2010, 07:50:45 am »
The reed added by itself will not make 'more power/torque' they just make the engine more flexible. It will do 3 parts of SFA unless the ports are changed to take advantage of the reed.
Offline k2000x
Re: 80cc reed block
« Reply #4 on: March 15, 2010, 01:02:09 pm »
can you do this lozza(port work) ive got to bring it to newcastle when i have a spare weekend..i need you to make a pipe aswell...is your shop near the jaguar repare place in broadmeadow
Re: 80cc reed block
« Reply #5 on: March 15, 2010, 04:31:50 pm »
I'll pm you details
