Author Topic: Toy #26.  (Read 27230 times)
Offline jimson
  • Sanctuary point N.S.W
Re: Toy #26.
« Reply #15 on: August 03, 2007, 10:21:31 pm »
Nathan SL100 has two down tubes on front of frame. I think the SL125 has one down tube at the front.
Offline Noel
Re: Toy #26.
« Reply #16 on: August 04, 2007, 07:39:29 am »
Probably only a 125 pipe on the 100.
I found a 325 17 trials tire from Kenda not sure if the have a full nobby.
Noel
« Last Edit: August 04, 2007, 07:44:51 am by Noel »
Quicksilver
Re: Toy #26.
« Reply #17 on: August 04, 2007, 12:26:49 pm »
Nathan.
Sorting though some bits today deciding what stays and what goes. I do have a quite good 325 x 17 nobby..
Re: Toy #26.
« Reply #18 on: August 04, 2007, 06:13:54 pm »
SL125 /100 use same frame OK. 100 has 19F /17R  inch wheels  125 has 21F/ 18R .  both have different shaped metal mud guards.  Later XL  CT CB CL 100 and 125 fit in, but you may have to swap sides and invert the front engine mounts from the early models ,and it all matchs up. Single downtube frames are Agi CTs and later XLs All "SL "100 /  125s have twin down tubes. .........Chinese upright motors fit   ;)...... OK.  and yes CB500/4 pistons do fit so buy a 500/4 big bore kit and have 4 x150cc sets.  ::) Tim
Offline gorby
Re: Toy #26.
« Reply #19 on: August 04, 2007, 08:16:20 pm »
some thing in memory bank tells me that early SL100's have a smaller piston pin,
that seem right Tim?
ps (havent forgot your parts)
Re: Toy #26.
« Reply #20 on: August 05, 2007, 08:36:04 pm »
A limited number do, some 125s do too.
Re: Toy #26.
« Reply #21 on: August 08, 2007, 08:24:07 pm »
  All "SL "100 /  125s have twin down tubes. ........  and yes CB500/4 pistons do fit so buy a 500/4 big bore kit and have 4 x150cc sets.  ::) Tim
geeze Timbo i thought youd get there but you didnt quick i was reading and reading and just waiting for the fit a 500 ...oh and rig a chair on it and a third wheel :O)
Re: Toy #26.
« Reply #22 on: August 09, 2007, 11:35:27 pm »
I have an early effort of what you spoke Freaky... Gave the front end (XL350) to Tony T recently. yes the 500/4 was made to fit in the 125 frame, was to flimsy so rebuilt with hybrid 550/4 Sl125 mix .both were solos.... and truly awful.... and a prick to make a set of headers and pipe! Those days seem to be over now for me so try some ideas yourself , it occansionly is worth the pain. Tim
