Author Topic: Can somone with a suzuki Zedder give me the full Model list for  (Read 2919 times)
Suzuki Carby Joint 13110-16500.
i need one for a 32mm carby and the same throat as the TM250, i assume there are other mofdel that used this same Intake joint that would be a shitload cheaper and easier to get than the Tm one, i just modified one for the RT piston port barrell and the little shit has started to crack where it moulds to the steal plate.
So i need to make another pronto for the NAts,.
IF you know of a similar mounting one even with 5mm closer stud holes would be interested in knowing.
thanks
Re: Can somone with a suzuki Zedder give me the full Model list for
« Reply #1 on: March 11, 2010, 01:31:20 am »
Part # = 13110-16500
Part Description = PIPE,INTAKE
Model Count = 12
TM250J 1972 246 TM250 CHAMPION OFF ROAD
TM250K 1973 246 TM250 CHAMPION OFF ROAD
TM250L 1974 246 TM250 CHAMPION OFF ROAD
TM250M 1975 246 TM250 CHAMPION OFF ROAD
TM400J 1972 396 TM400 CYCLONE OFF ROAD
TM400K 1973 396 TM400 CYCLONE OFF ROAD
TM400L 1974 396 TM400 CYCLONE OFF ROAD
TM400M 1975 396 TM400 CYCLONE OFF ROAD
TM400R 1971 396 TM400 CYCLONE OFF ROAD
TS250 1969 246 TS250 SAVAGE DUAL SPORT
TS400J 1972 396 TS400 APACHE DUAL SPORT
TS400K 1973 396 TS400 APACHE DUAL SPORT
so this is a 2 bolt intake manifold? if so have you tried IWT for a uni mikini one? TD hatricks have drawings with bolt spacings etc on their website. http://www.mikunioz.com/r_m_flanges.htm somewhere i have a better chart though. Also you could make one out of some plate with a short bit of round tube welded to it, then a length of radiator hose, if you have got space lengthwise i guess.
« Last Edit: March 11, 2010, 01:41:16 am by LWC82PE »
monaro308
« Reply #2 on: March 11, 2010, 01:36:52 am »
Beat me to it Leith  ;D
How the hell do you cut and past the results from the program??
I can only copy to clipboard...and from there its in la la land and i can't find it!
« Reply #3 on: March 11, 2010, 01:44:11 am »
FILE & COPY (control + C) in zedder, then EDIT & COPY (control + V) in internet explorer and it will paste it wherever the cursor is
monaro308
« Reply #4 on: March 11, 2010, 02:16:25 am »
Duh...here i've been trying to do the right click and copy and paste and never got the "copy" to come up!
Thanks Leith....i feel better now ;D
Offline oldmxracer
« Reply #5 on: March 11, 2010, 09:02:52 am »
I've been using Babbitts parts fish for this kind of stuff. Lists all models the # fits too.
http://www.babbittsonline.com/pages/parts/viewbybrand/default.aspx
« Reply #6 on: March 11, 2010, 09:28:47 am »
Thats it ? i thought maybe the katana and other multis would use it too.   thats a prity limited list and they probally would be old as shit too.
Thought about a pipe lieth but i need to cusion the vibration in the carb otherwise all the interanls will jingle out.
i had a look at the muks but not one i could see close enough, but will keep looking.
any one got a good cheap one above for sale, ? all the ones i have seen are cracking so wouldnt last 5 minites.
