Author Topic: Honda Gurus 2  (Read 1628 times)
Honda Gurus 2
« on: March 10, 2010, 02:20:36 pm »
Gents - how much water should you be adding to an 83 250 CR (from empty) - I added to the filler neck, kicked over a couple of times to move the water pump and topped up - ended up with maybe 800-900mls?  Is that enough?
ta
Rossco
Offline caps 999
Re: Honda Gurus 2
« Reply #1 on: March 10, 2010, 02:34:41 pm »
Sounds about right they don't hold huge amounts
MUGEN power
ianscr250
Re: Honda Gurus 2
« Reply #2 on: March 10, 2010, 04:27:14 pm »
make sure to crack the bleed screw to allow any air out
as mentioned it shouldnt take any more than a litre to fill
STW996
Re: Honda Gurus 2
« Reply #3 on: March 10, 2010, 04:40:19 pm »
That would be right Rossco, Don't be surprised if it kicks some of that out after the first ride. Rule of thumb (on my 84's) is about half an inch under the top of tank is the usually water level (approx half way to the core).
Air normally bleads out ok but when you fire it up remove the cap to see if you have good water flow.
Shane
Re: Honda Gurus 2
« Reply #4 on: March 11, 2010, 12:27:34 pm »
thanks Gents  ;D
Rossco
