Author Topic: wanted dr400 1980 axle  (Read 2208 times)
Offline caps 999
« on: March 09, 2010, 10:25:26 pm »
as above will pay cash
MUGEN power
Re: wanted dr400 1980 axle
« Reply #1 on: March 10, 2010, 12:53:33 am »
PE/TS axles will also work/are same
TT
« Reply #2 on: March 10, 2010, 07:31:42 am »
Front or rear, caps?
I've got a heap of SP/DR stuff and may just have one.
Maybe let me know the size too, to be sure.
« Reply #3 on: March 10, 2010, 08:47:49 am »
for some reason i was assuming front which is 12mm, but yeah, you didnt mention front or rear.
Offline caps 999
« Reply #4 on: March 10, 2010, 09:03:53 am »
Sorry it's a rear I'll measure it tonite
MUGEN power
DR
« Reply #5 on: March 10, 2010, 09:32:49 am »
Think you'll find PE/RM axles are different as they have the stepped area on the left. From memory the DR400 axles are 1 size all the way through. Pretty sure the DR400/500, GS400/425/450 and GT380's shared the same rear axle.
« Reply #6 on: March 10, 2010, 10:47:18 pm »
I will assume its a 1980 DR400 ST which is the Australian model and not the more enduro orientated USA spec model
so this is what i have come up with for DR400ST 64711-33000
that number doest show up on zedder, but i would have thought the axle would be the same as the SP400T.
if its the same as SP400T that means its common to 59 other model suzukis inc PE/TS/DS/RM
I find it hard to believe that the axle is only found on this one model so i have a feeling the part number i supplied above which is off a site that lists DR400ST (autralian spec) may  be wrong
DR
« Reply #7 on: March 11, 2010, 07:17:55 am »
Zedder shows that number as fitting 36 models Leith ??? namely the models I mentioned. Been using DR rear wheels on my RM400 for years ;)
« Last Edit: March 11, 2010, 07:19:59 am by Doc »
