Author Topic: XL350 side port Mikuni carby spec's  (Read 6263 times)
090
« on: March 07, 2010, 07:45:28 am »
The carby I have was jetted for a 420 but it has a stocker in it at present so it is running rich. I thought I would go down on the main but it had a Kehin jet in it so I don't know where it is at. It said 75 on it but also worried it was drilled out (shit of an idea who ever thought of that).
Any one have a starting point?
lc4
Re: XL350 side port Mikuni carby spec's
« Reply #1 on: March 07, 2010, 03:10:03 pm »
Standard Main jet for XL350 is 130,slow jet 48 (Keihin PW32)
Sorry can`t help with the Mikuni
Offline fatboyracing
« Reply #2 on: March 07, 2010, 05:33:59 pm »
Hi Brad,
My xl350 with a 420 kit has a mikuni carby and I pulled it apart today to check what I have been running . It has a 180 main jet I hope this helps
Fatboy
Offline sudman
« Reply #3 on: March 07, 2010, 06:48:15 pm »
I ran a 160 main with 36mm carb on a standard engine with big header & pipe. I also ran a 38mm carb with the same size jet just more top end & less bottom end.
090
« Reply #4 on: March 07, 2010, 08:10:48 pm »
Thanks guys, that helps heaps.
The other motor I have that is suppose to be a 420 seems to have a modified honda piston. I would expect it to have an after market piston in there. any one have bore and stroke spec's?
« Reply #5 on: March 07, 2010, 11:52:41 pm »
87mm XR/TRX400 white bro piston kit in our XL350-normal stroke.  8)
cheers S&A WA
TT
« Reply #6 on: March 08, 2010, 07:29:55 pm »
Hey Brad, I think there might be some useful info here for you.
http://www.oldrice.com/CarbStuff.htm
090
« Reply #7 on: March 08, 2010, 08:00:38 pm »
Excellent Tony!
Offline sudman
« Reply #8 on: March 12, 2010, 12:31:28 pm »
cheers S&A WA
Is there much you have to do to fit this piston other than a rebore to suit?
« Reply #9 on: March 13, 2010, 10:36:48 am »
cheers S&A WA
That all.... Not a lot of liner left once you run the boring tool through.
I think the last piston was a Wiseco from Ballards
S&A - WA
