Author Topic: interesting bultaco gm question  (Read 3253 times)
lms6201
« on: December 02, 2007, 07:31:25 pm »
 my bully friends , a question to answer if u will , or can  , where the 192 engines struck with an over stamp do u think ? and if so were the remaining mk 10 frames stamped with a 180 prefix   and (if changed ) the matching 192 engine,s serial # ? opinion,s pls
265coupe
Re: interesting bultaco gm question
« Reply #1 on: May 28, 2008, 02:46:39 pm »
I've got a 250GM that i've had for about 25years. The motor/ frame combo appears original.
Eng No: PM49202582
Frame No: PB18001485
Stamps appear original.
Any help?
Mick
lms6201
« Reply #2 on: May 29, 2008, 09:16:13 pm »
hi mick , yep ,lots of help , seems to confirm what i thought , yours (should)have a compliance plate on it ?
Offline BultacoMacca
« Reply #3 on: May 29, 2008, 10:49:46 pm »
My 370 engine has a 4 stamped over the 193 making it into a M493. Can't recall the frame its off at the painters. Gearbox was a wide ratio, so I had to convert it back to a close ratio box as I want to use it for MX.
265coupe
« Reply #4 on: May 30, 2008, 04:42:07 pm »
It did have a compliance plate but unfortunately it's been removed at some time before I bought it.
No real problem though as it'll end up as my pre78 racer (complete with gold/red paint and Frontera toolbox)
Any ideas as to how many were imported and how many might be still around?
My understanding was that they were left over Pursangs fitted with a mag, lighting kit and frontera bodywork. I was hoping that it still had the close ratio 'box. I last rode it years ago and remember that it was quite quick but can't recall how the gearing felt. It also had a Pursang pipe at the time.
Mick
lms6201
« Reply #5 on: June 01, 2008, 07:26:10 pm »
mick , they had a pursang pipe with an extra silencer on the end , unsure of the tran but as u say they were left over mk 10 pursangs over stamped with a 4 it,s hard to imagine the factory splitting them and changing the gears ,but it,s possible , but it,ll work geared up anyway, i have an alpina tran (same as 360/370 frontera) in my mk 2 pursang   just use 2nd gear to start ,
