Author Topic: Small end bearing spacer??  (Read 1972 times)
Offline Grunter215
« on: March 03, 2010, 06:55:26 pm »
I need to put a spacer/washer on piston pin between bearing and piston.What type is best to use(Thrust,hardened steel....???) Also how much gap should there be between bearing/piston
Re: Small end bearing spacer??
« Reply #1 on: March 03, 2010, 08:07:44 pm »
Do you have a lathe ????    if so buy a grade 8.8 bolt with a large head ....turn it down to right OD and ID and start parting off to correct thickness.
Offline holeshot buddy
  • sunshine coast qld
« Reply #2 on: March 03, 2010, 09:00:03 pm »
aluminium is fine for that application  ;)
follow me to first turn
