Author Topic: betor fork setup  (Read 2488 times)
Offline shortshifter
  • Sunshine Coast QLD
betor fork setup
« on: March 02, 2010, 10:55:09 am »
Guys looking for some input.Tried out the Montesa front end on CZ 250 on weekend.Initially way too soft with lots of static sag.played around with oil weights and amounts.Put in some bushes to give about 50mm of preload on top of spacer alloy washer small spring then large spring.This improved sag,but front end still bottoming out with slow rebound.Will new springs help here and where do you get them?or is it my riding techniques not putting enough weight on the back wheel?Holeshot's Montesa front end felt very light with lots of rebound compared to mine(although the 125 monty is a very light bike).What are you guys running?
Re: betor fork setup
« Reply #1 on: March 03, 2010, 08:12:58 am »
Okay Shortie ;D, I'm no expert in the field but it sounds to me you have too soft springs and too much dampening.
Having established that the starting point is to get heavier springs. Then the dampening.
Spacers preloading the spring doesn't change the spring rate. Good for a little fine tuning but not a solution for a fundamental failing.
As to replacement springs it depends on how much money and time you want to spend. The starting point would be to find out what forks you have. Do you know? They are Betors but off what, a trail bike, trials bikes, enduro, mx'er, 125, or 360?
You could measure the compression of the current spring and ask around for replacement or simply play mix and match with other springs. I would try anything that fits. I don't know what you have in the 'stash' but I have a couple of Betors and a range of old Yammy 34mm road bike, trail bike and MX springs that I would try. Just take a guesstimate, make sure there they are approximately right for length, there is no binding or fouling and give it a try ;)
« Reply #2 on: March 03, 2010, 10:45:47 am »
there is some new springs on ebay usa under stores betor about 8 different ones
jim
« Reply #3 on: March 04, 2010, 08:36:06 am »
Thanks Guys.Will follow all leads.
