Author Topic: PE175 Tank in good order  (Read 950 times)
Stewy138
« on: February 28, 2010, 12:29:42 pm »
PE175 tank in good order, surface finish is good (not painted, original plastic which has been polished) and has original style decals as per the C/N models.  A few large scratches at the front where triple clamp bolts have fouled, otherwise no cracks, leaks or blemishes.  Tank is clean inside (was used for the entire 2009 season) and petcock in good working order. Inlcudes the fuel cap in good order and comes with recently electroplated mounting brackets.  The tank is off a C model and should fit most PE models including other years and 175/250/400 models.
Asking $90, located in Brisbane.
